What is ApplicationStatus commandclass?
Posted: 26 Jul 2017 04:51
by taeold
I sometimes notice 'ApplicationStatus' commandclass appearing before my devices. Under most circumstances, my device doesn't include ApplicationStatus as one of it's commandclasses, but I occasionally notice it.
What is ApplicationStatus command? What does it mean w.r.t. z-way-server? Anyone has any idea?
Re: What is ApplicationStatus commandclass?
Posted: 26 Jul 2017 15:12
Application Status or Application Busy is a Command Class that allows the device to inform the sender (controller) that it is busy. It's ID is 0x22 (you should find it in the NIF). You can check Online Manual (
https://github.com/Z-Wave-Me/Z-Way-Manu ... wayDev.pdf) chapter 8.51
What means "commandclass appearing before my devices" ?
Posted: 26 Jul 2017 19:48
by taeold
Hey @PoltoS - thanks for your reply.
Poor wording - what I meant by that is that ApplicatonStatus command class usually does not appear under the device's data tree. Does it only make an appearance when a device is "Busy"?
Posted: 26 Jul 2017 21:06
No, it appears when device supports it. Most devices do not have it supported
Posted: 26 Jul 2017 22:38
by taeold
PoltoS - Any idea why a device might sometimes display ApplicationStatus as one of it's command classes, and sometimes not?
I have a script that runs hourly to check the commandclasses supported by a device by looking localhost/ZWave.zway/Run/devices. Every once in a while, the device that I have shows ApplicationStatus as one of the commandclass of this device. Most of the times it doesn't show ApplicationStatus at all.
I'm using z-way-server v2.3.0. The device displaying this behavior is Kwitset 914
https://www.kwikset.com/products/detail ... 15-ul.aspx
Posted: 27 Jul 2017 02:44
Provide us the log - we will see. May be the device do not announce this CC, but then send us a command and we instanciate it - you will then see it till then next Z-Way restart
Posted: 27 Jul 2017 18:59
by taeold
I think your theory is probably correct! I don't have the logs handy with me at the moment, and will post it over once I witness the phenomenon again. Thanks for you help!
