Create For()...
Posted: 22 Sep 2017 12:20
by NoName
Hello, i wanted to use this Code:
var numh = (192.168.1.102:8083/JS/Run/this.controller.devices.get("CounterTriggeringSensor_21").get("metrics:level"));
for(numh;numh>0;numh-1){
	192.168.1.102:8083/JS/Run/zway.devices[5].instances[0].commandClasses[0x20].Set(255);
    	192.168.1.102:8083/JS/Run/setTimeout(function(){zway.devices[5].instances[0].commandClasses[0x20].Set(0)},3000);
So a variable is created aut of a CounterTriggerin Sensor . The Switch should start numh times for a short time.
But it always says "Unexpected Number", but i have really no idea, what is wrong.
Could someone may help?
Greetings
Re: Create For()...
Posted: 24 Sep 2017 01:13
You need to learn JS a bit. Do you want to run this code on the Z-Way JS side?
var numh = this.controller.devices.get("CounterTriggeringSensor_21").get("metrics:level");
for(; numh > 0; numh--) {
    	setTimeout(function() { zway.devices[5].instances[0].commandClasses[0x20].Set(0) }, 3000);
But the code is still pretty useless - what the for loop is doing here?
