I have a Z-Way install running on a Raspberry Pi - using UZB, not Razberry.
The system constantly goes down with file system corruption - meaning I need to install the complete system over and over again. It has happened at least 6 or 7 times the last six months, and has now reached a level where my Z-Way server will only survive for a week or so.
We have 10-15 other Raspberry Pi's running around the house and they're completely stable - it's only the Z-Way server that keeps going down with a corrupt filesystem. I've tried two different RPi boards and three different SD cards, all with the same sad result.
How do you create a stable install of the Z-Way server?
Regards,
Lars
									File system corruption on Raspberry Pi
Best regards,
Lars
						Lars
- Z-Wave Support
Re: File system corruption on Raspberry Pi
Which Version of Z-Way do you use?
Which operation System do you use on Raspberry Pi?
Best regards
Z-Wave Support
Best regards
Z-Wave Support
The problem has existed with several versions - but right now I'm running 2.3.6 which I believe to be the latest.
I'm using Raspian Jessie Lite dated 2017-07-05.
Best regards,
Lars
						Lars
