I have just upgraded to 2.3.7 and I have seen that the Multi Button widget on the new mobile UI doesn't show the popup window that was used on previous versions to be able to control each of the buttons individually. Tapping the widget seems to toggle all the buttons of the group at the same time instead of showing the popup window that was shown before and that Multi Sensor widget still shows in 2.3.7.
Is this a bug or is it the new desired behavior?
Thank you!
