No more z-wave Devices Shown
altheeagle^
Post by altheeagle^ » 06 Jul 2018 20:29
Hi, today i upgradet the Firmware to v2.3.7 and after the Upgrade no Z-Wave Device is shown in the Dashboard. In the Expert Menu everthing is working. In the log i'm getting a lots of errors like this:
[2018-07-06 19:24:53.550] [E] [core] Callback execution error: TypeError: Cannot read property 'controller' of null
    at packetApplication (automation/modules/ZWave/index.js:558:63)
    at createOutgoingEntry (automation/modules/ZWave/index.js:693:12)
    at ZDataHolder.outH (automation/modules/ZWave/index.js:491:10)
All other Devices, like HTTP-Devices or JS-Devices are there and working.
I've done a couple of things via the z-way Api wich also doesn't work. I've restartet the raspian pi a couple times, I unplugged the UZB-Stick. Notthing worked.
Re: No more z-wave Devices Shown
Post by PoltoS » 07 Jul 2018 04:46
More logs would be nice. Sure files are correctly updated? Try to install the latest (or same) version again.
altheeagle^
Post by altheeagle^ » 09 Jul 2018 22:02
Thank you, i‘m currently not at home, but inwill try it tomorrow and report
altheeagle^
Post by altheeagle^ » 13 Jul 2018 17:48
I reinstalled the Software and it didn't helped. Because I have not so much Time fixing the System I recopied the previous Version of the Z-Way Server and now it works. I a couple of weeks I'm gonna try it again. But Thank you for your help :)
Popp Wod
Post by Popp Wod » 27 Jul 2018 12:12
What are the devices you were missing?
I had a minor but similar problem with Pan-08 roller shutters. On/off was no longer possible as the switches were missing. However the multi-level-switches were available.
I am now back to firmware 2.3.6. The Way server sometimes dies but thank to monit it will be restarted automatically.
