Qubino Flush 1D relay senzor pin not available
ipc
Post by ipc »
I am running 2.3.7 on a RaspberryPi + Z-Wave.Me RaZberry.
I have a Qubino Flush 1D Relay included, having pin I2 activated as 1=Home Security; Motion Detection, unknown location.
(The user guide of the Qubino device specifies for I2: Support Enable / Disable Endpoint I2 or select Notification Type and Event. Enabling I2, means that Endpoint (I2) will be present on UI)
I can see I2 available on on Expert interface/Control/Sensors, and here I can see that is triggering OK!
However through the application interface (/Configuration/Application/Selecting a application) there is no any application by which I can get information about the status of this senzor I2 pin.
Could you please advice how this I2 pin can I make available.
Thank you.
