Send SensorMultilevel unsolicited from controller
ridewithstyle
Re: Send SensorMultilevel unsolicited from controller
Post by ridewithstyle »
yes, I started with one byte and iterated up to 4 bytes, to no avail.
Can I provide anymore debug data to help you?
@aivs will check it
aivs
Post by aivs »
Spirit sends to Razberry Temperature Report in this format:
Spirit send report: [0x31, 0x05, 0x01, 0x42, 0x08, 0x09]
31 - CC Sensor Multilevel
05 - CC Multilevel Sensor Report
01 - Sensor Type Temperature
42 - Size:2, Scale: C, Precision: 2
08 - 22 °C
9A - 02 °C
Need to try send this report to spirit.
aivs
Post by aivs »
All works. From manual, report incoming:
Sensor type: Air Temperature
Scale: Celsius and Fahrenheit
Precision: 0, 1 and 2
Check new app ThermostatExternalSensorEmulation 1.2 in RaZberry, it perfectly send temperature report to Spirit.
ridewithstyle
Hi there,
I tried feeding back the data to the spirit and here are my results. For comparison, I let the spirit run 24h with a fixed target temperature of 19°C. To see that the values are real, there is an open window for 5 minutes last night that you can see in a temperature drop and resulting overshoot from the spirit.
This morning I switched to the app aivs reported, in version 1.2, freshly installed and set up. All I do is looping back the reported temperature to the spirit, please see attached screenshot for config details.
The attachment Z-way_config_2019-03-08 15_53_15-Z-Wave Smart Home.png is no longer available
Now you can see the resulting temperature in the room constantly climbing over the course of the day. Nobody in the room, no external source of heat, it's cold outside, no sunlight heating up the room.
The attachment Z-way_temperature_2019-03-08 15_49_39-Z-Wave Smart Home.png is no longer available
What am I doing wrong? The spirit parameters are as follows
Z-way_config_2019-03-08 15_53_15-Z-Wave Smart Home.png (69.57 KiB) Viewed 4371 times
Best Regards,
rws
ridewithstyle
Hi there,
somehow my attachments disappeared, did I violate any forum rules?
Regards,
rws
No. I suppose only one can be added in a message
viper123
Post by viper123 »
you are attempting to precisely tackle my concern. :- )
I additionally need to send spontaneous temp reports to the soul, so we can adjust the worth. I took window sensors and the temp report from the soul and gauged them with the numerical module to a reasonable worth.
in principle, the application esteem surpasses ought to precisely do that, however it just acknowledges activity esteems, not temperature readings. So perhaps the application esteem overwhelms could be a decent outline for your usage or you could expand the application? I myself have this subject in my excess and I need to fathom some more significant issues first prior to handling this point. In any case, possibly the application can support you.
