upgrade to 2.3.8 failed / transformation script failed
Posted: 04 Nov 2018 12:18
Dear all,
I tried to upgrade from 2.3.7 to 2.3.8. I'm running it using RPI3 and Raspbian jassie.
After the upgrade it failed with following error
/var/log/z-way-server.log
[2018-11-04 10:14:03.276] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2018-11-04 10:14:03.279] [core] Executing script: // Comon utilities and functions ...
[2018-11-04 10:14:03.290] [core] Executing script: // This script transforms old formats to new ...
[2018-11-04 10:14:03.758] [E] [core] result: Error: SyntaxError: Unexpected end of input
at automation/main.js:31:11
at Array.filter (native)
at automation/main.js:30:37
If I start it manually using /opt/z-way-server/z-way-server, it hangs
root@z-way-server:/opt/z-way-server# ./z-way-server
Z-Way version v2.3.8 from 2018-10-10 00:47:52 +0300 (build 854d8c466afa676694043ff7a9d17febb3bb01d6)
Module modhttp.so loaded
Module modinstaller.so loaded
Module modiconinstaller.so loaded
Module modws.so loaded
Module modhomekit.so loaded
Module modnotification2ext.so loaded
Module modskininstaller.so loaded
Module modzbw.so loaded
Module modenocean.so loaded
Module modzwave.so loaded
Module modsockets.so loaded
Module moddhs.so loaded
Module modcrypto.so loaded
Any help is more then welcome
