TP-Link HS110 module problem
Mike
Post by Mike »
Hi guys, I faced the problem during TP-Link devices using. I have a 3 TP-Link sockets one HS100 and two HS110. When I add it to the device menu, the HS100 works properly: HS110 turned off \ on after 3-5 clicks. In z-wave.log all clicks are registred (wi-fi problems are excluded 5m direct sight). HS110 always glitched. Seems there is some problem with the HS110 module. Could you check it or suggest me something?
I tried on raspberry 2 B+ and z-way on jessie v2.3.8
Thank you.
