Z-uno and Wire.h - maybe there is some problem?
Miklux
Post by Miklux »
Hi all,
I'm trying to realize a VOC and CO2 sensor using the Z-uno and a chip that works with I2C.
But when I try to compile I receive errors.
I'm using the Arduino IDE V 1.6.5 and this is my sketch:
// VOC & CO2 Sensor
// Based on MiCS-VZ-89TE
#include "Wire.h"
ZUNO_SETUP_CHANNELS(ZUNO_SENSOR_MULTILEVEL_CO2_LEVEL(getterCO2));
ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE); // to control other devices
#define MICS_VZ_89TE_ADDR 0x70 //0x70 default I2C address
#define MICS_VZ_89TE_ADDR_CMD_GETSTATUS 0x0C  // This command is used to read the VZ89 status coded with 6 bytes:
#define MICS_VZ_89TE_DATE_CODE 0x0D
float co2;
float voc;
float reactivity;
float statusS;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  Wire.begin();
  //mics1.begin();
void loop() {
  readSensor();
  delay(500);
  Serial.print("CO2: ");
  Serial.println(co2);
  Serial.print("VOC: ");
  Serial.println(voc);
  //Serial.print("Reactivity: ");
  //Serial.println(mics1.reactivity);
  // send report to controller (Life Line group)
  zunoSendReport(1);
float getterCO2() {
  return co2;
void readData(byte reg, uint8_t data1[]) {
    uint8_t i =0;
    Wire.beginTransmission((uint8_t)MICS_VZ_89TE_ADDR);
    Wire.write((uint8_t)reg); //This send the command to get data
    Wire.write(0x0);
    Wire.write(0x0);
    Wire.write(0x0);
    Wire.write(0x0);
    Wire.write(0x0);
    Wire.endTransmission();
    Wire.beginTransmission(0xE1);
    Wire.requestFrom((uint8_t)MICS_VZ_89TE_ADDR, (byte)7);
    for (i==0; i<7; i++) {
      data1[i] = Wire.read();
void readSensor(void) {
    static uint8_t data2[7];
    readData(MICS_VZ_89TE_ADDR_CMD_GETSTATUS, data2);
    statusS = data2[5];
    co2 = (data2[1] - 13) * (1600.0 / 229) + 400; // ppm: 400 .. 2000
    voc = (data2[0] - 13) * (1000.0/229); // ppb: 0 .. 1000
    reactivity = (data2[4]+(256*data2[3])+(65536*data2[2]));
The following are the errors:
	C:\Users\Michele\AppData\Local\Temp\build5438819384211814526.tmp/z-wave_VOC_CO2.cpp
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: Wire.cpp with SDCPP...
Compiling Wire_sdcpp_.cpp ...
Preprocessing file: z-wave_VOC_CO2.cpp with SDCPP...
Compiling z-wave_VOC_CO2_sdcpp_.cpp ...
z-wave_VOC_CO2.ino:64:11:warning:equality comparison result unused
z-wave_VOC_CO2.ino:64:11:warning:equality comparison result unusedCompiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
Compiling file "Wire_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "Wire_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Wire_ucxx.rel" "Wire_ucxx".asm
Wire_ucxx.c:1317: warning 85: in function __cxx__TwoWire__method__endTransmission_0105 unreferenced function argument : 'stop'
Wire_ucxx.c:1361: warning 84: 'auto' variable 'ret' may be used before initialization
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
HLCore_ucxx.c:562: warning 85: in function delayLoops unreferenced function argument : 'v'
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
Compiling file "z-wave_VOC_CO2_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\Michele\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.70\zuno_toolchain/sdcc/\bin\..\include"  "z-wave_VOC_CO2_ucxx.c"
sdcpp.exe: fatal error: when writing output to : Broken pipe
z-wave_VOC_CO2_ucxx.c:580: syntax error: token -> 'data1' ; column 40
Error. SDCC returned: 1
Errore durante la compilazione
Re: Z-uno and Wire.h - maybe there is some problem?
Use uint8_t * data1 instead as the argument
Miklux
Post by Miklux »
Ok, thank you , I'm trying it just now.
Miklux
Post by Miklux »
I try and it compile well, but after do this I have a great problem: the board doesn't start.
I don't know what is the problem: the two leds don't flashes, also if i try to press the association button.
it seems that the device doesn't start...
If I press the reset button the led flash but not more.
It seems the device is dead...
Could you help me please?
Thank you in advance
Mik
Try rescue mode first. Keep BTN pressed and click RST. Does it start to blink green?
Miklux
Post by Miklux »
Hi! I tryied and the green led is blinking!
Now I'm thinking to upload again the bootloader.
Thank you very much,
Mik
PoltoS wrote:
18 Jan 2019 00:42
