Delay() not working
johnny_boy_1984
Delay() not working
Post by johnny_boy_1984 »
I am trying for my first project to digitalWrite several pins high or low with a delay, but the delays are ignored. I used the control relay example and added extra output pins. The result is all three defined pins are going on and off simultaniously instead of with a delay.
 * This example shows basic Switch Binary functionality
 * Control an external relay on pin 13
// pin number, where relay is connected
#define RELAY_PIN9     9
#define RELAY_PIN10    10
#define RELAY_PIN11    11
// variable to store current relay state
byte lastSetValue;
// next macro sets up the Z-Uno channels
// in this example we set up 1 switch binary channel
// you can read more on http://z-uno.z-wave.me/Reference/ZUNO_SWITCH_BINARY/
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(getter, setter));
void setup() {
  pinMode(RELAY_PIN9, OUTPUT); // set up relay pin as output
  pinMode(RELAY_PIN10, OUTPUT); // set up relay pin as output
  pinMode(RELAY_PIN11, OUTPUT); // set up relay pin as output
void loop() {
  // loop is empty, because all the control comes over the Z-Wave
// function, which returns the previously saved relay value
// this function runs only once the controller asks
byte getter() {
    return lastSetValue;
// function, which sets new relay state
// this function runs only once the controller sends new value
void setter(byte newValue) {
  // newValue is a variable, holding a "value"
  // which came from the controller or other Z-Wave device
  if (newValue > 0) { // if greater then zero
    digitalWrite(RELAY_PIN9, HIGH); //turn relay on
    delay(1000);
    digitalWrite(RELAY_PIN10, HIGH); //turn relay on
    delay(1000);
    digitalWrite(RELAY_PIN11, HIGH); //turn relay on
  } else {            // if equals zero
    digitalWrite(RELAY_PIN9, LOW); //turn relay off
    delay(1000);
    digitalWrite(RELAY_PIN10, LOW); //turn relay off
    delay(1000);
    digitalWrite(RELAY_PIN11, LOW); //turn relay off
  // save the new value in a variable
  lastSetValue = newValue;
Re: Delay() not working
delay is not allowed in getters and setters. Please check the manual.
This is because setter and getter is like an interrupt
johnny_boy_1984
Is it possible to create a delay on another way? I tried a lot of possibilities, but i am kinda stuck here.
What i would like to do is opening and closing ports one after another in a sequence.
We suggest to do minimal things in the getter/setter. Like saving the state to variable. The rest should be done in the loop
johnny_boy_1984
I get the hint, i created an integer that changes when the state of the setter is changed, the rest happens in the loop. It is working now:
byte lastSetValue;
int state;    // integer to store the switch value
void setup() {
void loop() {
  if (state == 1) { // if state equals 1
    delay (1000);
    digitalWrite(RELAY_PIN11, HIGH); //turn relay off
          } else {            // if state equal snot 1
    delay (1000);
  // loop used for delayed ports
byte getter() {
    state = 1;
    state = 0;
