Z-way server goes down spontaneously
GokMasE
Re: Z-way server goes down spontaneously
Post by GokMasE »
I see a new z-way dev build (z-way-3.0.4-48-gbfd8c05_armhf.deb) was uploaded yesterday evening. Was there anything changed in regard to the stability problems?
Regards,
/Joakim
This is a new test build. We have improved stability with TCP/UDP sockets. This should not affect HTTP requests that we think are causing the problem, but we are not able to reproduce the issue anymore. Please help us to check if the issue is still there. If so, we are preparing a big inestigation inside V8 to see why it crashes. It is somewhere inside the huge V8 JS engine.
GokMasE
Post by GokMasE »
I gave the new test build a go and still get a crash within the usual <=2 days of uptime (this time around 1d 18 hours).
GDB results:
3 0x712a65e0
4 0x712a6610
used_nodes_ = 53
5 0x3cf28
6
3 0x712a6610
4 0x712a6620
used_nodes_ = 54
5 0x3cf28
6
3 0x712a6620
4 0x712a6640
used_nodes_ = 55
5 0x3cf28
6
3 0x712a6640
4 0x712a7300
used_nodes_ = 56
5 0x3cf28
6
3 0x712a7300
4 0x712a6520
used_nodes_ = 57
5 0x3cf28
6
3 0x712a6520
4 0x66311c00
used_nodes_ = 58
5 0x3cf28
6
3 0x66311c00
4 0x66311a80
used_nodes_ = 22
5 0x3cf28
6
3 0x66311a80
4 0x66311a40
used_nodes_ = 23
5 0x3cf28
6
3 0x66311a40
4 0x66311a50
used_nodes_ = 24
5 0x3cf28
6
3 0x66311a50
4 0x66311a60
used_nodes_ = 25
5 0x3cf28
6
3 0x66311a60
4 0x712a6dc0
used_nodes_ = 26
5 0x3cf28
6
3 0x712a6dc0
4 0x712a6db0
used_nodes_ = 59
5 0x3cf28
6
3 0x712a6db0
4 0x712a6d90
used_nodes_ = 60
5 0x3cf28
6
3 0x712a6d90
4 0x712a6d80
used_nodes_ = 61
5 0x3cf28
6
3 0x712a6d80
4 0x712a6d40
used_nodes_ = 62
5 0x3cf28
6
3 0x712a6d40
4 0x712a6d20
used_nodes_ = 63
5 0x3cf28
6
3 0x712a6d20
4 0x712a6d10
used_nodes_ = 64
5 0x3cf28
6
3 0x712a6d10
4 0x712a6d00
used_nodes_ = 65
5 0x3cf28
6
3 0x712a6d00
4 0x712a6cf0
used_nodes_ = 66
5 0x3cf28
6
3 0x712a6cf0
4 0x712a6ce0
used_nodes_ = 67
5 0x3cf28
6
3 0x712a6ce0
4 0x712a6cd0
used_nodes_ = 68
5 0x3cf28
6
3 0x712a6cd0
4 0x712a6ca0
used_nodes_ = 69
5 0x3cf28
6
3 0x712a6ca0
4 0x712a6c90
used_nodes_ = 70
5 0x3cf28
6
3 0x712a6c90
4 0x712a6c70
used_nodes_ = 71
5 0x3cf28
6
3 0x712a6c70
4 0x712a6c30
used_nodes_ = 72
5 0x3cf28
6
3 0x712a6c30
4 0x712a6b70
used_nodes_ = 73
5 0x3cf28
6
3 0x712a6b70
4 0x712a6b60
used_nodes_ = 74
5 0x3cf28
6
3 0x712a6b60
4 0x712a6b40
used_nodes_ = 75
5 0x3cf28
6
3 0x712a6b40
4 0x712a6b30
used_nodes_ = 76
5 0x3cf28
6
3 0x712a6b30
4 0x712a6b10
used_nodes_ = 77
5 0x3cf28
6
3 0x712a6b10
4 0x712a6af0
used_nodes_ = 78
5 0x3cf28
6
3 0x712a6af0
4 0x712a6ae0
used_nodes_ = 79
5 0x3cf28
6
3 0x712a6ae0
4 0x712a6ac0
used_nodes_ = 80
5 0x3cf28
6
3 0x712a6ac0
4 0x712a6ab0
used_nodes_ = 81
5 0x3cf28
6
3 0x712a6ab0
4 0x712a6aa0
used_nodes_ = 82
5 0x3cf28
6
3 0x712a6aa0
4 0x712a6a80
used_nodes_ = 83
5 0x3cf28
6
3 0x712a6a80
4 0x712a6a70
used_nodes_ = 84
5 0x3cf28
6
3 0x712a6a70
4 0x712a6a30
used_nodes_ = 85
5 0x3cf28
6
3 0x712a6a30
4 0x712a6a20
used_nodes_ = 86
5 0x3cf28
6
3 0x712a6a20
4 0x712a6a00
used_nodes_ = 87
5 0x3cf28
6
3 0x712a6a00
4 0x712a69f0
used_nodes_ = 88
5 0x3cf28
6
3 0x712a69f0
4 0x712a69c0
used_nodes_ = 89
5 0x3cf28
6
3 0x712a69c0
4 0x712a6930
used_nodes_ = 90
5 0x3cf28
6
3 0x712a6930
4 0x712a6920
used_nodes_ = 91
5 0x3cf28
6
3 0x712a6920
4 0x712a6900
used_nodes_ = 92
5 0x3cf28
6
3 0x712a6900
4 0x712a68f0
used_nodes_ = 93
5 0x3cf28
6
3 0x712a68f0
4 0x6631d418
used_nodes_ = 94
5 0x3cf28
6
3 0x6631d418
4 0x6631d0a8
used_nodes_ = 12
5 0x3cf28
6
3 0x6631d0a8
4 0x7125ea00
used_nodes_ = 13
5 0x3cf28
6
3 0x7125ea00
4 0x6631d888
used_nodes_ = 14
5 0x3cf28
6
3 0x6631d888
4 0x6631cf18
used_nodes_ = 14
5 0x3cf28
6
3 0x6631cf18
4 0x6631cf08
used_nodes_ = 15
5 0x3cf28
6
3 0x6631cf08
4 0x6631cd98
used_nodes_ = 16
5 0x3cf28
6
3 0x6631cd98
4 0x6631d5b8
used_nodes_ = 17
5 0x3cf28
6
[New Thread 0x6d4fc450 (LWP 3263)]
3 0x6631d888
4 0x7125ea00
used_nodes_ = 15
5 0x3cf28
6
3 0x7125ea00
4 0x6631d0a8
used_nodes_ = 1
5 0x3cf28
6
3 0x6631d0a8
4 0x6631d418
used_nodes_ = 16
5 0x3cf28
6
3 0x6631d418
4 0x712a68f0
used_nodes_ = 17
5 0x3cf28
6
3 0x712a68f0
4 0x712a6900
used_nodes_ = 14
5 0x3cf28
6
3 0x712a6900
4 0x712a6920
used_nodes_ = 15
5 0x3cf28
6
3 0x712a6920
4 0x712a6930
used_nodes_ = 16
5 0x3cf28
6
3 0x712a6930
4 0x712a69c0
used_nodes_ = 17
5 0x3cf28
6
3 0x712a69c0
4 0x712a69f0
used_nodes_ = 18
5 0x3cf28
6
3 0x712a69f0
4 0x712a6a00
used_nodes_ = 19
5 0x3cf28
6
3 0x712a6a00
4 0x712a6a20
used_nodes_ = 20
5 0x3cf28
6
[Thread 0x6dcfd450 (LWP 3261) exited]
3 0x66301678
4 0x712f83b0
used_nodes_ = 14
5 0x3cf28
6
3 0x712f83b0
4 0x712a6a20
used_nodes_ = 14
5 0x3cf28
6
3 0x712a6a20
4 0x712a6a30
used_nodes_ = 21
5 0x3cf28
6
[New Thread 0x6dcfd450 (LWP 3264)]
3 0x712a6a30
4 0x712a6a70
used_nodes_ = 22
5 0x3cf28
6
3 0x712a6a70
4 0x712a6a80
used_nodes_ = 23
5 0x3cf28
6
3 0x712a6a80
4 0x712a6aa0
used_nodes_ = 24
5 0x3cf28
6
3 0x712a6aa0
4 0x712a6ab0
used_nodes_ = 25
5 0x3cf28
6
3 0x712a6ab0
4 0x712a6ac0
used_nodes_ = 26
5 0x3cf28
6
3 0x712a6ac0
4 0x712a6ae0
used_nodes_ = 27
5 0x3cf28
6
3 0x712a6ae0
4 0x712a6af0
used_nodes_ = 28
5 0x3cf28
6
3 0x712a6af0
4 0x712a6b10
used_nodes_ = 29
5 0x3cf28
6
3 0x712a6b10
4 0x712a6b30
used_nodes_ = 30
5 0x3cf28
6
3 0x712a6b30
4 0x712a6b40
used_nodes_ = 31
5 0x3cf28
6
3 0x712a6b40
4 0x712a6b60
used_nodes_ = 32
5 0x3cf28
6
3 0x712a6b60
4 0x712a6b70
used_nodes_ = 33
5 0x3cf28
6
3 0x712a6b70
4 0x712a6c30
used_nodes_ = 34
5 0x3cf28
6
3 0x712a6c30
4 0x712a6c70
used_nodes_ = 35
5 0x3cf28
6
3 0x712a6c70
4 0x712a6c90
used_nodes_ = 36
5 0x3cf28
6
3 0x712a6c90
4 0x712a6ca0
used_nodes_ = 37
5 0x3cf28
6
3 0x712a6ca0
4 0x712a6cd0
used_nodes_ = 38
5 0x3cf28
6
3 0x712a6cd0
4 0x712a6ce0
used_nodes_ = 39
5 0x3cf28
6
3 0x712a6ce0
4 0x712a6cf0
used_nodes_ = 40
5 0x3cf28
6
3 0x712a6cf0
4 0x712a6d00
used_nodes_ = 41
5 0x3cf28
6
3 0x712a6d00
4 0x712a6d10
used_nodes_ = 41
5 0x3cf28
6
3 0x712a6a20
4 0x712a6d00
used_nodes_ = 42
5 0x3cf28
6
[Thread 0x6dcfd450 (LWP 3264) exited]
3 0x712a6d00
4 0x703026d0
used_nodes_ = 43
5 0x3cf28
6
3 0x703026d0
4 0x23700
used_nodes_ = 29
Thread 7 "zway/core" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x732fe450 (LWP 11432)]
0x76c03e8c in v8::internal::GlobalHandles::Create(v8::internal::Object*) ()
   from libs/libv8.so
(gdb) i thr
  Id   Target Id         Frame
  1    Thread 0x76ff6140 (LWP 11423) "z-way-server" 0x76350030 in nanosleep ()
    at ../sysdeps/unix/syscall-template.S:84
  2    Thread 0x73aff450 (LWP 11427) "OptimizingCompi" 0x765f6068 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x5b51c)
    at ../sysdeps/unix/sysv/linux/futex-internal.h:205
  3    Thread 0x74062450 (LWP 11428) "v8:SweeperThrea" 0x765f6068 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x5b67c)
  4    Thread 0x73b82450 (LWP 11429) "v8:SweeperThrea" 0x765f6068 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x5b79c)
  5    Thread 0x73b71450 (LWP 11430) "v8:SweeperThrea" 0x765f6068 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x5b8bc)
  6    Thread 0x73b60450 (LWP 11431) "v8:SweeperThrea" 0x765f6068 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x5b9dc)
* 7    Thread 0x732fe450 (LWP 11432) "zway/core" 0x76c03e8c in v8::internal::GlobalHandles::Create(v8::internal::Object*) () from libs/libv8.so
  8    Thread 0x726ff450 (LWP 11435) "zway/webserver" 0x76350030 in nanosleep
    () at ../sysdeps/unix/syscall-template.S:84
  9    Thread 0x71efe450 (LWP 11436) "zway/timers" 0x76350030 in nanosleep ()
---Type <return> to continue, or q <return> to quit---
  10   Thread 0x710ff450 (LWP 11437) "zway/core" 0x765f6f10 in __lll_lock_wait
    (futex=futex@entry=0x72906f90, private=0) at lowlevellock.c:46
  72809 Thread 0x6d4fc450 (LWP 3263) "zway/core" 0x7637c120 in poll ()
(gdb) bt
#0  0x76c03e8c in v8::internal::GlobalHandles::Create(v8::internal::Object*) ()
   from libs/libv8.so
#1  0x76b50c1c in v8::V8::GlobalizeReference(v8::internal::Isolate*, v8::internal::Object**) () from libs/libv8.so
#2  0x74110cb0 in zwjs::DHWrapper::Setup(v8::Isolate*, v8::Handle<v8::Object>)
    () from ./modules/moddhs.so
#3  0x74105b38 in zwjs::DataHolder::New(zwjs::Environment*, zwjs::DHWrapper*)
#4  0x74105180 in zwjs::DataHolder::New(zwjs::Environment*, _ZDataHolder*) ()
#5  0x741097cc in zwjs::DataHolder::NamedPropertyGetter(v8::Local<v8::String>, v8::PropertyCallbackInfo<v8::Value> const&) () from ./modules/moddhs.so
#6  0x76b70e78 in v8::internal::PropertyCallbackArguments::Call(void (*)(v8::Local<v8::String>, v8::PropertyCallbackInfo<v8::Value> const&), v8::Local<v8::String>) () from libs/libv8.so
#7  0x76de054c in v8::internal::LoadWithInterceptor(v8::internal::Arguments*, PropertyAttributes*) () from libs/libv8.so
#8  0x76de1624 in v8::internal::LoadPropertyWithInterceptorForLoad(int, v8::internal::Object**, v8::internal::Isolate*) () from libs/libv8.so
#9  0x2520a3a8 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
(gdb)
Z-way server log snippet:
[2020-03-06 19:21:25.252] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:21:25.252] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:21:25.262] [D] [zway] SENDING (cb 0x5c): ( 01 0A 00 13 02 03 25 01 00 25 5C BA )
[2020-03-06 19:21:25.265] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:25.268] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:25.268] [D] [zway] SENT ACK
[2020-03-06 19:21:25.268] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:25.293] [D] [zway] RECEIVED: ( 01 07 00 13 5C 00 00 02 B5 )
[2020-03-06 19:21:25.293] [D] [zway] SENT ACK
[2020-03-06 19:21:25.293] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:21:25.294] [D] [zway] SendData Response with callback 0x5c received: received by recipient
[2020-03-06 19:21:25.294] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:25.294] [D] [zway] SETDATA devices.2.data.lastSend = 15636368 (0x00ee9790)
[2020-03-06 19:21:25.294] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:21:25.294] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:21:25.335] [D] [zway] SENDING (cb 0x5d): ( 01 09 00 13 02 02 25 02 25 5D BA )
[2020-03-06 19:21:25.337] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:25.341] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:25.341] [D] [zway] SENT ACK
[2020-03-06 19:21:25.341] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:25.365] [D] [zway] RECEIVED: ( 01 07 00 13 5D 00 00 02 B4 )
[2020-03-06 19:21:25.366] [D] [zway] SENT ACK
[2020-03-06 19:21:25.366] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:21:25.366] [D] [zway] SendData Response with callback 0x5d received: received by recipient
[2020-03-06 19:21:25.366] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:25.366] [D] [zway] SETDATA devices.2.data.lastSend = 15636375 (0x00ee9797)
[2020-03-06 19:21:25.366] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:21:25.366] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:21:25.376] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 00 D5 )
[2020-03-06 19:21:25.376] [D] [zway] SENT ACK
[2020-03-06 19:21:25.377] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:25.377] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:21:25.377] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = False
[2020-03-06 19:21:25.420] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"off","location":1}
[2020-03-06 19:21:25.421] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : off : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=off
[2020-03-06 19:21:25.722] [I] [core] Request was successful
[2020-03-06 19:21:27.105] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 12 00 00 D0 )
[2020-03-06 19:21:27.106] [D] [zway] SENT ACK
[2020-03-06 19:21:27.106] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:27.106] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.800000
[2020-03-06 19:21:27.106] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:27.106] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:27.106] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:27.110] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.8 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.8
[2020-03-06 19:21:27.447] [I] [core] Request was successful
[2020-03-06 19:21:27.513] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:21:28.102] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 07 00 00 C5 )
[2020-03-06 19:21:28.103] [D] [zway] SENT ACK
[2020-03-06 19:21:28.103] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:28.103] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 0.700000
[2020-03-06 19:21:28.103] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:28.104] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:28.104] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:28.107] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 0.7 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=0.7
[2020-03-06 19:21:28.685] [I] [core] Request was successful
[2020-03-06 19:21:29.120] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 0C 00 00 A2 )
[2020-03-06 19:21:29.121] [D] [zway] SENT ACK
[2020-03-06 19:21:29.121] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:29.121] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 1.200000
[2020-03-06 19:21:29.121] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:29.121] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:29.122] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:29.133] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 1.2 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=1.2
[2020-03-06 19:21:29.407] [I] [core] Request was successful
[2020-03-06 19:21:40.162] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 02 00 00 C0 )
[2020-03-06 19:21:40.162] [D] [zway] SENT ACK
[2020-03-06 19:21:40.163] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:40.163] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 0.200000
[2020-03-06 19:21:40.163] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:40.163] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:40.163] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:40.187] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 0.2 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=0.2
[2020-03-06 19:21:40.629] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"on","1":{}}
[2020-03-06 19:21:40.629] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:21:40.629] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:21:40.630] [D] [zway] SENDING (cb 0x5e): ( 01 0A 00 13 02 03 25 01 FF 25 5E 47 )
[2020-03-06 19:21:40.632] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:40.636] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:40.636] [D] [zway] SENT ACK
[2020-03-06 19:21:40.636] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:40.660] [D] [zway] RECEIVED: ( 01 07 00 13 5E 00 00 02 B7 )
[2020-03-06 19:21:40.660] [D] [zway] SENT ACK
[2020-03-06 19:21:40.660] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:21:40.660] [D] [zway] SendData Response with callback 0x5e received: received by recipient
[2020-03-06 19:21:40.660] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:40.660] [D] [zway] SETDATA devices.2.data.lastSend = 15637878 (0x00ee9d76)
[2020-03-06 19:21:40.660] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:21:40.660] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:21:40.701] [D] [zway] SENDING (cb 0x5f): ( 01 09 00 13 02 02 25 02 25 5F B8 )
[2020-03-06 19:21:40.702] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:40.707] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:40.707] [D] [zway] SENT ACK
[2020-03-06 19:21:40.707] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:40.731] [D] [zway] RECEIVED: ( 01 07 00 13 5F 00 00 02 B6 )
[2020-03-06 19:21:40.731] [D] [zway] SENT ACK
[2020-03-06 19:21:40.731] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:21:40.731] [D] [zway] SendData Response with callback 0x5f received: received by recipient
[2020-03-06 19:21:40.731] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:40.731] [D] [zway] SETDATA devices.2.data.lastSend = 15637885 (0x00ee9d7d)
[2020-03-06 19:21:40.732] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:21:40.732] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:21:40.741] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 FF 2A )
[2020-03-06 19:21:40.741] [D] [zway] SENT ACK
[2020-03-06 19:21:40.741] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:40.741] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:21:40.741] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = True
[2020-03-06 19:21:40.771] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"on","location":1}
[2020-03-06 19:21:40.772] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : on : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=on
[2020-03-06 19:21:41.178] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:21:41.178] [D] [zway] SENT ACK
[2020-03-06 19:21:41.179] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:41.179] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:21:41.179] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:41.179] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:41.179] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:41.191] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:21:41.246] [I] [core] Request was successful
[2020-03-06 19:21:41.560] [I] [core] Request was successful
[2020-03-06 19:21:42.087] [I] [core] Request was successful
[2020-03-06 19:21:42.875] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:21:45.699] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:21:53.251] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"off","1":{}}
[2020-03-06 19:21:53.252] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:21:53.252] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:21:53.253] [D] [zway] SENDING (cb 0x60): ( 01 0A 00 13 02 03 25 01 00 25 60 86 )
[2020-03-06 19:21:53.255] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:53.259] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:53.260] [D] [zway] SENT ACK
[2020-03-06 19:21:53.260] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:53.284] [D] [zway] RECEIVED: ( 01 07 00 13 60 00 00 02 89 )
[2020-03-06 19:21:53.284] [D] [zway] SENT ACK
[2020-03-06 19:21:53.285] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:21:53.285] [D] [zway] SendData Response with callback 0x60 received: received by recipient
[2020-03-06 19:21:53.285] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:53.285] [D] [zway] SETDATA devices.2.data.lastSend = 15639121 (0x00eea251)
[2020-03-06 19:21:53.285] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:21:53.285] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:21:53.325] [D] [zway] SENDING (cb 0x61): ( 01 09 00 13 02 02 25 02 25 61 86 )
[2020-03-06 19:21:53.327] [D] [zway] RECEIVED ACK
[2020-03-06 19:21:53.331] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:21:53.331] [D] [zway] SENT ACK
[2020-03-06 19:21:53.331] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:21:53.355] [D] [zway] RECEIVED: ( 01 07 00 13 61 00 00 02 88 )
[2020-03-06 19:21:53.356] [D] [zway] SENT ACK
[2020-03-06 19:21:53.356] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:21:53.356] [D] [zway] SendData Response with callback 0x61 received: received by recipient
[2020-03-06 19:21:53.356] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:21:53.356] [D] [zway] SETDATA devices.2.data.lastSend = 15639128 (0x00eea258)
[2020-03-06 19:21:53.356] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:21:53.356] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:21:53.368] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 00 D5 )
[2020-03-06 19:21:53.368] [D] [zway] SENT ACK
[2020-03-06 19:21:53.368] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:53.369] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:21:53.369] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = False
[2020-03-06 19:21:53.396] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"off","location":1}
[2020-03-06 19:21:53.396] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : off : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=off
[2020-03-06 19:21:53.703] [I] [core] Request was successful
[2020-03-06 19:21:55.491] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:21:56.224] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 0A 00 00 C8 )
[2020-03-06 19:21:56.224] [D] [zway] SENT ACK
[2020-03-06 19:21:56.224] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:56.225] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.000000
[2020-03-06 19:21:56.225] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:56.225] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:56.225] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:56.228] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1
[2020-03-06 19:21:57.323] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:21:57.802] [D] [zway] SENT ACK
[2020-03-06 19:21:57.803] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:57.803] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:21:57.803] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:57.803] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:57.803] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:57.804] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:21:57.804] [D] [zway] SENT ACK
[2020-03-06 19:21:57.804] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:57.804] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:21:57.804] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:57.805] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:57.805] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:57.815] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:21:57.815] [D] [zway] SENT ACK
[2020-03-06 19:21:57.815] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:57.816] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:21:57.816] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:57.816] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:57.816] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:57.825] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:21:57.826] [D] [zway] SENT ACK
[2020-03-06 19:21:57.826] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:57.826] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:21:57.826] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:57.826] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:57.826] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:57.837] [I] [core] Request was successful
[2020-03-06 19:21:57.841] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:21:57.878] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:21:57.913] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:21:57.959] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:21:58.112] [I] [core] Can not make request: Server returned nothing (no headers, no data)
[2020-03-06 19:21:58.132] [I] [core] Can not make request: Server returned nothing (no headers, no data)
[2020-03-06 19:21:58.235] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 0D 00 00 CF )
[2020-03-06 19:21:58.236] [D] [zway] SENT ACK
[2020-03-06 19:21:58.236] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:58.236] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.300000
[2020-03-06 19:21:58.236] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:58.236] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:58.236] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:58.245] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.3 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.3
[2020-03-06 19:21:58.328] [I] [core] Request was successful
[2020-03-06 19:21:58.641] [I] [core] Request was successful
[2020-03-06 19:21:59.250] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 04 00 00 AA )
[2020-03-06 19:21:59.250] [D] [zway] SENT ACK
[2020-03-06 19:21:59.251] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:21:59.251] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.400000
[2020-03-06 19:21:59.251] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:21:59.251] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:21:59.251] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:21:59.260] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.4 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.4
[2020-03-06 19:21:59.565] [I] [core] Request was successful
[2020-03-06 19:22:01.068] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:01.251] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 11 00 00 D3 )
[2020-03-06 19:22:01.251] [D] [zway] SENT ACK
[2020-03-06 19:22:01.251] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:01.251] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.700000
[2020-03-06 19:22:01.252] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:01.252] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:01.252] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:01.258] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.7 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.7
[2020-03-06 19:22:01.389] [I] [core] Request was successful
[2020-03-06 19:22:02.257] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 12 00 00 BC )
[2020-03-06 19:22:02.257] [D] [zway] SENT ACK
[2020-03-06 19:22:02.258] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:02.258] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 1.800000
[2020-03-06 19:22:02.258] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:02.258] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:02.258] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:02.263] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 1.8 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=1.8
[2020-03-06 19:22:02.506] [I] [core] Request was successful
[2020-03-06 19:22:03.263] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 05 00 00 C7 )
[2020-03-06 19:22:03.264] [D] [zway] SENT ACK
[2020-03-06 19:22:03.264] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:03.264] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 0.500000
[2020-03-06 19:22:03.264] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:03.264] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:03.265] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:03.268] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 0.5 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=0.5
[2020-03-06 19:22:03.726] [I] [core] Request was successful
[2020-03-06 19:22:04.272] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:22:04.272] [D] [zway] SENT ACK
[2020-03-06 19:22:04.272] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:04.272] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:22:04.272] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:04.272] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:04.273] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:04.285] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:22:04.363] [I] [core] Request was successful
[2020-03-06 19:22:09.247] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"on","1":{}}
[2020-03-06 19:22:09.247] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:22:09.247] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:22:09.253] [D] [zway] SENDING (cb 0x62): ( 01 0A 00 13 02 03 25 01 FF 25 62 7B )
[2020-03-06 19:22:09.254] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:09.259] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:09.259] [D] [zway] SENT ACK
[2020-03-06 19:22:09.259] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:09.284] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 0D 00 00 CF )
[2020-03-06 19:22:09.284] [D] [zway] SENT ACK
[2020-03-06 19:22:09.284] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:09.284] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.300000
[2020-03-06 19:22:09.285] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:09.285] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:09.285] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:09.293] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.3 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.3
[2020-03-06 19:22:09.314] [D] [zway] RECEIVED: ( 01 07 00 13 62 00 00 06 8F )
[2020-03-06 19:22:09.314] [D] [zway] SENT ACK
[2020-03-06 19:22:09.314] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:22:09.314] [D] [zway] SendData Response with callback 0x62 received: received by recipient
[2020-03-06 19:22:09.314] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:09.314] [D] [zway] SETDATA devices.2.data.lastSend = 15640698 (0x00eea87a)
[2020-03-06 19:22:09.315] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:22:09.315] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:22:09.356] [D] [zway] SENDING (cb 0x63): ( 01 09 00 13 02 02 25 02 25 63 84 )
[2020-03-06 19:22:09.358] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:09.362] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:09.362] [D] [zway] SENT ACK
[2020-03-06 19:22:09.362] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:09.387] [D] [zway] RECEIVED: ( 01 07 00 13 63 00 00 01 89 )
[2020-03-06 19:22:09.387] [D] [zway] SENT ACK
[2020-03-06 19:22:09.388] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:22:09.388] [D] [zway] SendData Response with callback 0x63 received: received by recipient
[2020-03-06 19:22:09.388] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:09.388] [D] [zway] SETDATA devices.2.data.lastSend = 15640705 (0x00eea881)
[2020-03-06 19:22:09.388] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:22:09.388] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:22:09.397] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 FF 2A )
[2020-03-06 19:22:09.397] [D] [zway] SENT ACK
[2020-03-06 19:22:09.398] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:09.398] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:22:09.398] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = True
[2020-03-06 19:22:09.434] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"on","location":1}
[2020-03-06 19:22:09.434] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : on : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=on
[2020-03-06 19:22:09.481] [I] [core] Can not make request: Server returned nothing (no headers, no data)
[2020-03-06 19:22:09.501] [I] [core] Request was successful
[2020-03-06 19:22:10.288] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 03 00 00 C1 )
[2020-03-06 19:22:10.288] [D] [zway] SENT ACK
[2020-03-06 19:22:10.288] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:10.288] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 0.300000
[2020-03-06 19:22:10.288] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:10.289] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:10.289] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:10.301] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 0.3 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=0.3
[2020-03-06 19:22:10.627] [I] [core] Request was successful
[2020-03-06 19:22:11.305] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 06 00 00 A8 )
[2020-03-06 19:22:11.305] [D] [zway] SENT ACK
[2020-03-06 19:22:11.305] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:11.306] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.600000
[2020-03-06 19:22:11.306] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:11.306] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:11.306] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:11.318] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.6 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.6
[2020-03-06 19:22:11.449] [I] [core] Request was successful
[2020-03-06 19:22:11.551] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:13.774] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:25.267] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"off","1":{}}
[2020-03-06 19:22:25.268] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:22:25.268] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:22:25.277] [D] [zway] SENDING (cb 0x64): ( 01 0A 00 13 02 03 25 01 00 25 64 82 )
[2020-03-06 19:22:25.279] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:25.283] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:25.283] [D] [zway] SENT ACK
[2020-03-06 19:22:25.283] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:25.307] [D] [zway] RECEIVED: ( 01 07 00 13 64 00 00 02 8D )
[2020-03-06 19:22:25.307] [D] [zway] SENT ACK
[2020-03-06 19:22:25.307] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:22:25.307] [D] [zway] SendData Response with callback 0x64 received: received by recipient
[2020-03-06 19:22:25.307] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:25.308] [D] [zway] SETDATA devices.2.data.lastSend = 15642273 (0x00eeaea1)
[2020-03-06 19:22:25.308] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:22:25.308] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:22:25.348] [D] [zway] SENDING (cb 0x65): ( 01 09 00 13 02 02 25 02 25 65 82 )
[2020-03-06 19:22:25.350] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:25.354] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:25.354] [D] [zway] SENT ACK
[2020-03-06 19:22:25.354] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:25.379] [D] [zway] RECEIVED: ( 01 07 00 13 65 00 00 02 8C )
[2020-03-06 19:22:25.379] [D] [zway] SENT ACK
[2020-03-06 19:22:25.379] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:22:25.379] [D] [zway] SendData Response with callback 0x65 received: received by recipient
[2020-03-06 19:22:25.379] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:25.379] [D] [zway] SETDATA devices.2.data.lastSend = 15642280 (0x00eeaea8)
[2020-03-06 19:22:25.380] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:22:25.380] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:22:25.389] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 00 D5 )
[2020-03-06 19:22:25.389] [D] [zway] SENT ACK
[2020-03-06 19:22:25.390] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:25.390] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:22:25.390] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = False
[2020-03-06 19:22:25.436] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"off","location":1}
[2020-03-06 19:22:25.436] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : off : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=off
[2020-03-06 19:22:25.526] [I] [core] Request was successful
[2020-03-06 19:22:27.517] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:28.435] [D] [zway] RECEIVED: ( 01 12 00 04 00 0B 0C 60 0D 03 03 31 05 01 44 00 00 08 E9 13 )
[2020-03-06 19:22:28.435] [D] [zway] SENT ACK
[2020-03-06 19:22:28.436] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:28.436] [D] [zway] SETDATA devices.11.instances.3.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2020-03-06 19:22:28.437] [D] [zway] SETDATA devices.11.instances.3.commandClasses.49.data.1.scaleString = "°C"
[2020-03-06 19:22:28.437] [D] [zway] SETDATA devices.11.instances.3.commandClasses.49.data.1.val = 22.809999
[2020-03-06 19:22:28.438] [D] [zway] SETDATA devices.11.instances.3.commandClasses.49.data.1 = Empty
[2020-03-06 19:22:28.455] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_11-3-49-1 : 22.81 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_11-3-49-1&Lev=22.81
[2020-03-06 19:22:28.456] [D] [zway] RECEIVED: ( 01 12 00 04 00 0B 0C 60 0D 04 04 31 05 01 44 00 00 08 40 BA )
[2020-03-06 19:22:28.456] [D] [zway] SENT ACK
[2020-03-06 19:22:28.458] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:28.459] [D] [zway] SETDATA devices.11.instances.4.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2020-03-06 19:22:28.460] [D] [zway] SETDATA devices.11.instances.4.commandClasses.49.data.1.scaleString = "°C"
[2020-03-06 19:22:28.460] [D] [zway] SETDATA devices.11.instances.4.commandClasses.49.data.1.val = 21.120001
[2020-03-06 19:22:28.461] [D] [zway] SETDATA devices.11.instances.4.commandClasses.49.data.1 = Empty
[2020-03-06 19:22:28.511] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_11-4-49-1 : 21.1200016 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_11-4-49-1&Lev=21.1200016
[2020-03-06 19:22:28.566] [I] [core] Can not make request: Server returned nothing (no headers, no data)
[2020-03-06 19:22:28.566] [I] [core] Request was successful
[2020-03-06 19:22:29.706] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:34.394] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 16 00 00 D4 )
[2020-03-06 19:22:34.394] [D] [zway] SENT ACK
[2020-03-06 19:22:34.398] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:34.398] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 2.200000
[2020-03-06 19:22:34.399] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:34.399] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:34.399] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:34.407] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 2.2 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=2.2
[2020-03-06 19:22:34.472] [I] [core] Request was successful
[2020-03-06 19:22:35.400] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 05 00 00 C7 )
[2020-03-06 19:22:35.400] [D] [zway] SENT ACK
[2020-03-06 19:22:35.400] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:35.400] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 0.500000
[2020-03-06 19:22:35.400] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:35.401] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:35.401] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:35.409] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 0.5 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=0.5
[2020-03-06 19:22:35.843] [I] [core] Request was successful
[2020-03-06 19:22:36.415] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 01 00 00 AF )
[2020-03-06 19:22:36.415] [D] [zway] SENT ACK
[2020-03-06 19:22:36.416] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:36.416] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 0.100000
[2020-03-06 19:22:36.416] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:36.416] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:36.416] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:36.422] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 0.1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=0.1
[2020-03-06 19:22:36.487] [I] [core] Request was successful
[2020-03-06 19:22:41.246] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"on","1":{}}
[2020-03-06 19:22:41.247] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:22:41.247] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:22:41.252] [D] [zway] SENDING (cb 0x66): ( 01 0A 00 13 02 03 25 01 FF 25 66 7F )
[2020-03-06 19:22:41.253] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:41.258] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:41.258] [D] [zway] SENT ACK
[2020-03-06 19:22:41.258] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:41.282] [D] [zway] RECEIVED: ( 01 07 00 13 66 00 00 02 8F )
[2020-03-06 19:22:41.282] [D] [zway] SENT ACK
[2020-03-06 19:22:41.282] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:22:41.282] [D] [zway] SendData Response with callback 0x66 received: received by recipient
[2020-03-06 19:22:41.282] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:41.282] [D] [zway] SETDATA devices.2.data.lastSend = 15643844 (0x00eeb4c4)
[2020-03-06 19:22:41.282] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:22:41.282] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:22:41.326] [D] [zway] SENDING (cb 0x67): ( 01 09 00 13 02 02 25 02 25 67 80 )
[2020-03-06 19:22:41.328] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:41.332] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:41.332] [D] [zway] SENT ACK
[2020-03-06 19:22:41.332] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:41.356] [D] [zway] RECEIVED: ( 01 07 00 13 67 00 00 01 8D )
[2020-03-06 19:22:41.356] [D] [zway] SENT ACK
[2020-03-06 19:22:41.357] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:22:41.357] [D] [zway] SendData Response with callback 0x67 received: received by recipient
[2020-03-06 19:22:41.357] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:41.357] [D] [zway] SETDATA devices.2.data.lastSend = 15643851 (0x00eeb4cb)
[2020-03-06 19:22:41.357] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:22:41.357] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:22:41.367] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 FF 2A )
[2020-03-06 19:22:41.367] [D] [zway] SENT ACK
[2020-03-06 19:22:41.368] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:41.368] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:22:41.368] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = True
[2020-03-06 19:22:41.557] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"on","location":1}
[2020-03-06 19:22:41.558] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : on : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=on
[2020-03-06 19:22:41.608] [I] [core] Request was successful
[2020-03-06 19:22:43.487] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:45.712] [D] [zway] Job 0x13: deleted from queue
[2020-03-06 19:22:51.465] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 10 00 00 D2 )
[2020-03-06 19:22:51.465] [D] [zway] SENT ACK
[2020-03-06 19:22:51.465] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:51.465] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.600000
[2020-03-06 19:22:51.465] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:51.466] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:51.466] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:51.471] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.6 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.6
[2020-03-06 19:22:52.484] [D] [zway] RECEIVED: ( 01 14 00 04 00 06 0E 60 0D 01 00 32 02 21 34 00 00 00 0A 00 00 A4 )
[2020-03-06 19:22:52.484] [D] [zway] SENT ACK
[2020-03-06 19:22:52.484] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:52.484] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.val = 1.000000
[2020-03-06 19:22:52.485] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:52.485] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:52.485] [D] [zway] SETDATA devices.6.instances.1.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:52.487] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-1-50-2 : 1 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-1-50-2&Lev=1
[2020-03-06 19:22:53.467] [I] [core] ---  ZWayVDev_zway_2-0-37 performCommand processing: {"0":"off","1":{}}
[2020-03-06 19:22:53.468] [I] [zway] Adding job: SwitchBinary Set
[2020-03-06 19:22:53.468] [I] [zway] Adding job: SwitchBinary Get
[2020-03-06 19:22:53.470] [D] [zway] SENDING (cb 0x68): ( 01 0A 00 13 02 03 25 01 00 25 68 8E )
[2020-03-06 19:22:53.471] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:53.475] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:53.475] [D] [zway] SENT ACK
[2020-03-06 19:22:53.476] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:53.489] [I] [core] Can not make request: Server returned nothing (no headers, no data)
[2020-03-06 19:22:53.500] [D] [zway] RECEIVED: ( 01 07 00 13 68 00 00 02 81 )
[2020-03-06 19:22:53.500] [D] [zway] SENT ACK
[2020-03-06 19:22:53.501] [I] [zway] Job 0x13 (SwitchBinary Set): Delivered
[2020-03-06 19:22:53.501] [D] [zway] SendData Response with callback 0x68 received: received by recipient
[2020-03-06 19:22:53.501] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:53.501] [D] [zway] SETDATA devices.2.data.lastSend = 15645046 (0x00eeb976)
[2020-03-06 19:22:53.501] [D] [zway] Job 0x13 (SwitchBinary Set): success
[2020-03-06 19:22:53.501] [I] [zway] Removing job: SwitchBinary Set
[2020-03-06 19:22:53.541] [D] [zway] SENDING (cb 0x69): ( 01 09 00 13 02 02 25 02 25 69 8E )
[2020-03-06 19:22:53.543] [D] [zway] RECEIVED ACK
[2020-03-06 19:22:53.547] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2020-03-06 19:22:53.547] [D] [zway] SENT ACK
[2020-03-06 19:22:53.547] [D] [zway] Delivered to Z-Wave stack
[2020-03-06 19:22:53.563] [D] [zway] RECEIVED: ( 01 07 00 13 69 00 00 02 80 )
[2020-03-06 19:22:53.563] [D] [zway] SENT ACK
[2020-03-06 19:22:53.563] [I] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2020-03-06 19:22:53.563] [D] [zway] SendData Response with callback 0x69 received: received by recipient
[2020-03-06 19:22:53.563] [D] [zway] SETDATA devices.2.data.lastSendInternal = **********
[2020-03-06 19:22:53.563] [D] [zway] SETDATA devices.2.data.lastSend = 15645052 (0x00eeb97c)
[2020-03-06 19:22:53.563] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2020-03-06 19:22:53.564] [I] [zway] Waiting for job reply: SwitchBinary Get
[2020-03-06 19:22:53.573] [D] [zway] RECEIVED: ( 01 09 00 04 00 02 03 25 03 00 D5 )
[2020-03-06 19:22:53.573] [D] [zway] SENT ACK
[2020-03-06 19:22:53.573] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:53.573] [D] [zway] Received reply on job (SwitchBinary Get)
[2020-03-06 19:22:53.573] [D] [zway] SETDATA devices.2.instances.0.commandClasses.37.data.level = False
[2020-03-06 19:22:53.609] [I] [core] Notification: device-info (device-OnOff): {"dev":"Switch (2.0)","l":"off","location":1}
[2020-03-06 19:22:53.610] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_2-0-37 : off : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_2-0-37&Lev=off
[2020-03-06 19:22:53.701] [I] [core] Request was successful
[2020-03-06 19:22:54.479] [D] [zway] RECEIVED: ( 01 10 00 04 00 06 0A 32 02 21 34 00 00 00 0C 00 00 CE )
[2020-03-06 19:22:54.480] [D] [zway] SENT ACK
[2020-03-06 19:22:54.480] [D] [zway] SETDATA devices.6.data.lastReceived = 0 (0x00000000)
[2020-03-06 19:22:54.480] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.val = 1.200000
[2020-03-06 19:22:54.480] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.delta = 0 (0x00000000)
[2020-03-06 19:22:54.480] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2020-03-06 19:22:54.480] [D] [zway] SETDATA devices.6.instances.0.commandClasses.50.data.2 = Empty
[2020-03-06 19:22:54.493] [I] [core] http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=%DEVICE%&Lev=%VALUE% : ZWayVDev_zway_6-0-50-2 : 1.2 : http://192.168.1.3:1025/ZWave?Cmd=CBck&Dev=ZWayVDev_zway_6-0-50-2&Lev=1.2
Okey, we will make a version with more debug output
Please try this one with a lot of debug output: z-way-3.0.4-56-gb7f1c2f_armhf.deb
Would be nice if you can run it as
LD_LIBRARY_PATH=libs ./z-way-server -l 0 -L -
to see together the debug output and the log.
GokMasE
Post by GokMasE »
Ok, the new debug build installed and seems to run although there are some errors reported that I don't know if they are to be considered normal/expected at this stage:
  • Error: 'debug-port' number is out of range. Skipping it.
  • [2020-03-09 21:48:59.416] [E] [core] result: Error: Error: Failed to bind to 8083
    at Error (native)
    at automation/Webserver.js:10:6
    at automation/main.js:91:2
    [2020-03-09 21:48:59.418] [E] [core] result: Error: Error: Uncaught Error: Failed to bind to 8083
    at Error (native)
Here is what I see in PuTTY window when starting up:
pi@raspberrypi:/opt/z-way-server $ sudo /etc/init.d/z-way-server stop
Stopping z-way-server: done.
pi@raspberrypi:/opt/z-way-server $ sudo LD_LIBRARY_PATH=libs ./z-way-server -l 0 -L -
Z-Way version v3.0.4-56-gb7f1c2f from 2020-03-09 03:01:46 +0300 (build b7f1c2f442d59a37ec73fe675f8b3d850e6ddf60)
Looking for modules in ./modules
Module modzwave.so loaded
Module modws.so loaded
Module modzbw.so loaded
Module modnotification2ext.so loaded
Module modiconinstaller.so loaded
Module modskininstaller.so loaded
Module modinstaller.so loaded
Module modenocean.so loaded
Module modcrypto.so loaded
Module moddhs.so loaded
Module modhomekit.so loaded
Module modhttp.so loaded
Module modsockets.so loaded
>> I U 0
>> First free 0x2046490
>> Block 0x2046480
  X 0x2046480  . 0x2046490  . 0x20464a0  . 0x20464b0  . 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
  . 0x2046580  . 0x2046590  . 0x20465a0  . 0x20465b0  . 0x20465c0  . 0x20465d0  . 0x20465e0  . 0x20465f0  . 0x2046600  . 0x2046610  . 0x2046620  . 0x2046630  . 0x2046640  . 0x2046650  . 0x2046660  . 0x2046670
  . 0x2046680  . 0x2046690  . 0x20466a0  . 0x20466b0  . 0x20466c0  . 0x20466d0  . 0x20466e0  . 0x20466f0  . 0x2046700  . 0x2046710  . 0x2046720  . 0x2046730  . 0x2046740  . 0x2046750  . 0x2046760  . 0x2046770
  . 0x2046780  . 0x2046790  . 0x20467a0  . 0x20467b0  . 0x20467c0  . 0x20467d0  . 0x20467e0  . 0x20467f0  . 0x2046800  . 0x2046810  . 0x2046820  . 0x2046830  . 0x2046840  . 0x2046850  . 0x2046860  . 0x2046870
  . 0x2046880  . 0x2046890  . 0x20468a0  . 0x20468b0  . 0x20468c0  . 0x20468d0  . 0x20468e0  . 0x20468f0  . 0x2046900  . 0x2046910  . 0x2046920  . 0x2046930  . 0x2046940  . 0x2046950  . 0x2046960  . 0x2046970
  . 0x2046980  . 0x2046990  . 0x20469a0  . 0x20469b0  . 0x20469c0  . 0x20469d0  . 0x20469e0  . 0x20469f0  . 0x2046a00  . 0x2046a10  . 0x2046a20  . 0x2046a30  . 0x2046a40  . 0x2046a50  . 0x2046a60  . 0x2046a70
  . 0x2046a80  . 0x2046a90  . 0x2046aa0  . 0x2046ab0  . 0x2046ac0  . 0x2046ad0  . 0x2046ae0  . 0x2046af0  . 0x2046b00  . 0x2046b10  . 0x2046b20  . 0x2046b30  . 0x2046b40  . 0x2046b50  . 0x2046b60  . 0x2046b70
  . 0x2046b80  . 0x2046b90  . 0x2046ba0  . 0x2046bb0  . 0x2046bc0  . 0x2046bd0  . 0x2046be0  . 0x2046bf0  . 0x2046c00  . 0x2046c10  . 0x2046c20  . 0x2046c30  . 0x2046c40  . 0x2046c50  . 0x2046c60  . 0x2046c70
  . 0x2046c80  . 0x2046c90  . 0x2046ca0  . 0x2046cb0  . 0x2046cc0  . 0x2046cd0  . 0x2046ce0  . 0x2046cf0  . 0x2046d00  . 0x2046d10  . 0x2046d20  . 0x2046d30  . 0x2046d40  . 0x2046d50  . 0x2046d60  . 0x2046d70
  . 0x2046d80  . 0x2046d90  . 0x2046da0  . 0x2046db0  . 0x2046dc0  . 0x2046dd0  . 0x2046de0  . 0x2046df0  . 0x2046e00  . 0x2046e10  . 0x2046e20  . 0x2046e30  . 0x2046e40  . 0x2046e50  . 0x2046e60  . 0x2046e70
  . 0x2046e80  . 0x2046e90  . 0x2046ea0  . 0x2046eb0  . 0x2046ec0  . 0x2046ed0  . 0x2046ee0  . 0x2046ef0  . 0x2046f00  . 0x2046f10  . 0x2046f20  . 0x2046f30  . 0x2046f40  . 0x2046f50  . 0x2046f60  . 0x2046f70
  . 0x2046f80  . 0x2046f90  . 0x2046fa0  . 0x2046fb0  . 0x2046fc0  . 0x2046fd0  . 0x2046fe0  . 0x2046ff0  . 0x2047000  . 0x2047010  . 0x2047020  . 0x2047030  . 0x2047040  . 0x2047050  . 0x2047060  . 0x2047070
  . 0x2047080  . 0x2047090  . 0x20470a0  . 0x20470b0  . 0x20470c0  . 0x20470d0  . 0x20470e0  . 0x20470f0  . 0x2047100  . 0x2047110  . 0x2047120  . 0x2047130  . 0x2047140  . 0x2047150  . 0x2047160  . 0x2047170
  . 0x2047180  . 0x2047190  . 0x20471a0  . 0x20471b0  . 0x20471c0  . 0x20471d0  . 0x20471e0  . 0x20471f0  . 0x2047200  . 0x2047210  . 0x2047220  . 0x2047230  . 0x2047240  . 0x2047250  . 0x2047260  . 0x2047270
  . 0x2047280  . 0x2047290  . 0x20472a0  . 0x20472b0  . 0x20472c0  . 0x20472d0  . 0x20472e0  . 0x20472f0  . 0x2047300  . 0x2047310  . 0x2047320  . 0x2047330  . 0x2047340  . 0x2047350  . 0x2047360  . 0x2047370
  . 0x2047380  . 0x2047390  . 0x20473a0  . 0x20473b0  . 0x20473c0  . 0x20473d0  . 0x20473e0  . 0x20473f0  . 0x2047400  . 0x2047410  . 0x2047420  . 0x2047430  . 0x2047440  . 0x2047450  . 0x2047460  . 0x2047470
[2020-03-09 21:48:58.039] [I] [core] Executing script: /*** Z-Way Home Automation Engine main executable ***************************** ...
[2020-03-09 21:48:58.042] [I] [core] Executing script: // Comon utilities and functions ...
[2020-03-09 21:48:58.049] [I] [core] Executing script: // This script transforms old formats to new ...
[2020-03-09 21:48:59.230] [I] [core] Executing script: /*! EventEmitter2 https://github.com/hij1nx/EventEmitter2 Copyright (c) 2013 hij1nx Licensed under the MIT license.*/ ...
[2020-03-09 21:48:59.250] [I] [core] Executing script: //     Underscore.js 1.8.3 ...
[2020-03-09 21:48:59.273] [I] [core] Executing script: /*! Papa Parse v4.1.2 https://github.com/mholt/PapaParse */ ...
[2020-03-09 21:48:59.298] [I] [core] Executing script: /* @license zlib.js 2012 - imaya [ https://github.com/imaya/zlib.js ] The MIT License */ ...
[2020-03-09 21:48:59.317] [I] [core] Executing script: // BAOS_API_2011_01_29_001 ...
[2020-03-09 21:48:59.318] [I] [core] Executing script: // Converts IntelHex into binary 128 kB file ...
[2020-03-09 21:48:59.319] [I] [core] Executing script: // Public domain version of Base64 encoder/decoder found somewhere in the Internet ...
[2020-03-09 21:48:59.320] [I] [core] Executing script: /* ...
[2020-03-09 21:48:59.323] [I] [core] Executing script: /*** Z-Way HA Virtual Device base class *************************************** ...
[2020-03-09 21:48:59.326] [I] [core] Executing script: /*** Z-Way DevicesCollection class ************************************ ...
>> I U 1
>> First free 0x20464a0
>> Block 0x2046480
  X 0x2046480  X 0x2046490  . 0x20464a0  . 0x20464b0  . 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
[2020-03-09 21:48:59.353] [I] [core] Executing script: /*** Z-Way HA Controller class module ***************************************** ...
[2020-03-09 21:48:59.356] [I] [core] Executing script: /*** Automation Webserver Auth Controller ************************************* ...
[2020-03-09 21:48:59.359] [I] [core] Executing script: /*** Z-Way HA Automation module base class ************************************ ...
[2020-03-09 21:48:59.360] [I] [core] Executing script: /*** Initialize Webserver and Handlers ***************************************** ...
>> I U 2
>> First free 0x20464b0
>> Block 0x2046480
  X 0x2046480  X 0x2046490  X 0x20464a0  . 0x20464b0  . 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> I U 3
>> First free 0x20464c0
>> Block 0x2046480
  X 0x2046480  X 0x2046490  X 0x20464a0  X 0x20464b0  . 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> D U 4
>> Block 0x2046480
  X 0x2046480  X 0x2046490  . 0x20464a0  X 0x20464b0  . 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> I U 3
>> Block 0x2046480
>> I U 4
>> First free 0x20464d0
>> Block 0x2046480
  X 0x2046480  X 0x2046490  X 0x20464a0  X 0x20464b0  X 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
    at Error (native)
    at Error (native)
>> D U 5
>> Block 0x2046480
  X 0x2046480  . 0x2046490  X 0x20464a0  X 0x20464b0  X 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> D U 4
>> Block 0x2046480
  X 0x2046480  . 0x2046490  . 0x20464a0  X 0x20464b0  X 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> D U 3
>> Block 0x2046480
  X 0x2046480  . 0x2046490  . 0x20464a0  . 0x20464b0  X 0x20464c0  . 0x20464d0  . 0x20464e0  . 0x20464f0  . 0x2046500  . 0x2046510  . 0x2046520  . 0x2046530  . 0x2046540  . 0x2046550  . 0x2046560  . 0x2046570
>> D U 2
>> Block 0x2046480
The contents from PuTTY window above is all the text output I get when starting the program, it does not seem to log to console window which I guess is due to GDB not running.
It seems starting z-way server this way means I am not supposed to use GDB for logging data from this build, is that correct?
Regards,
/Joakim
Re: Z-way server goes down spontaneously
The other instance of Z-Way is still running. Please stop the other Z-Way first using
or stop the gdb session if it is running in gdb.
Yes, no gdb needed here. We know the point it crashes - it is inside V8 engine and now we are debugging this part.
GokMasE
Post by GokMasE »
Hm, this is strange - if you look in the log from the PuTTY window, you can see that I did just that in the first line:
"pi@raspberrypi:/opt/z-way-server $ sudo /etc/init.d/z-way-server stop
Stopping z-way-server: done."
If it was running in gdb, it will not stop it. Close the gdb session, please
GokMasE
Post by GokMasE »
Ok, good to know.
I seem to recall rebooting the RPi before the server launch in the log above, but will make a clean start tonight to make sure.
