Interview FGBS-222 not completed
ibjr
Post by ibjr »
The interview of the new Fibaro FGBS-222 device does not complete. It fails in V2.3.8 as well as in version V3.0.0-rc17.
This is what the log files shows after a "force interview" on the two missing items:
Force Interview SwitchBinary:
[2019-02-08 14:02:04.879] [zway] Removing job: Get background noise level
[2019-02-08 14:02:23.705] [zway] Using security scheme S2 Authenticated
[2019-02-08 14:02:23.705] [zway] Adding job: SwitchBinary Get
[2019-02-08 14:02:23.707] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get
[2019-02-08 14:02:23.717] [D] [zway] SENDING (cb 0x75): ( 01 15 00 13 08 0E 9F 03 91 00 61 99 4F 1A C1 65 47 9D ED 52 25 75 CE )
[2019-02-08 14:02:23.717] [D] [zway] Secure payload: ( 25 02 )
[2019-02-08 14:02:23.720] [D] [zway] RECEIVED ACK
[2019-02-08 14:02:23.724] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-02-08 14:02:23.724] [D] [zway] SENT ACK
[2019-02-08 14:02:23.724] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get): Response received - transfered to encapsulated jobs
[2019-02-08 14:02:23.724] [D] [zway] Delivered to Z-Wave stack
[2019-02-08 14:02:23.748] [D] [zway] RECEIVED: ( 01 18 00 13 75 00 00 02 00 E0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 62 )
[2019-02-08 14:02:23.748] [D] [zway] SENT ACK
[2019-02-08 14:02:23.748] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get): Callback received - transfered to encapsulated jobs
[2019-02-08 14:02:23.748] [zway] Job 0x13 (SwitchBinary Get): Delivered
[2019-02-08 14:02:23.748] [D] [zway] SendData Response with callback 0x75 received: received by recipient
[2019-02-08 14:02:23.748] [D] [zway] Job 0x13 (SwitchBinary Get): success
[2019-02-08 14:02:23.748] [zway] Waiting for job reply: SwitchBinary Get
[2019-02-08 14:02:23.748] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get): Delivered
[2019-02-08 14:02:23.749] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2019-02-08 14:02:23.749] [D] [zway] SETDATA devices.8.data.lastSend = 448379 (0x0006d77b)
[2019-02-08 14:02:23.749] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get): success
[2019-02-08 14:02:23.749] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), SwitchBinary Get
[2019-02-08 14:02:25.085] [D] [zway] Job 0x3b: deleted from queue
[2019-02-08 14:02:25.874] [W] [zway] Reply not received before timeout for job (SwitchBinary Get)
[2019-02-08 14:02:34.872] [I] [zway] Adding job: Get background noise level
Force interview CentralScene:
[2019-02-08 14:05:23.018] [I] [zway] Using security scheme S2 Authenticated
[2019-02-08 14:05:23.019] [I] [zway] Adding job: CentralScene Supported Get
[2019-02-08 14:05:23.020] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get
[2019-02-08 14:05:23.030] [D] [zway] SENDING (cb 0x76): ( 01 15 00 13 08 0E 9F 03 92 00 9C 24 CE 4F 20 AB 1E F3 54 63 25 76 CA )
[2019-02-08 14:05:23.030] [D] [zway] Secure payload: ( 5B 01 )
[2019-02-08 14:05:23.033] [D] [zway] RECEIVED ACK
[2019-02-08 14:05:23.037] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-02-08 14:05:23.037] [D] [zway] SENT ACK
[2019-02-08 14:05:23.037] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Response received - transfered to encapsulated jobs
[2019-02-08 14:05:23.037] [D] [zway] Delivered to Z-Wave stack
[2019-02-08 14:05:23.038] [D] [zway] Delivered to Z-Wave stack
[2019-02-08 14:05:23.061] [D] [zway] RECEIVED: ( 01 18 00 13 76 00 00 02 00 E0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 61 )
[2019-02-08 14:05:23.061] [D] [zway] SENT ACK
[2019-02-08 14:05:23.061] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Callback received - transfered to encapsulated jobs
[2019-02-08 14:05:23.061] [I] [zway] Job 0x13 (CentralScene Supported Get): Delivered
[2019-02-08 14:05:23.061] [D] [zway] SendData Response with callback 0x76 received: received by recipient
[2019-02-08 14:05:23.061] [D] [zway] Job 0x13 (CentralScene Supported Get): success
[2019-02-08 14:05:23.061] [I] [zway] Waiting for job reply: CentralScene Supported Get
[2019-02-08 14:05:23.061] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): Delivered
[2019-02-08 14:05:23.062] [D] [zway] SendData Response with callback 0x76 received: received by recipient
[2019-02-08 14:05:23.062] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2019-02-08 14:05:23.062] [D] [zway] SETDATA devices.8.data.lastSend = 466080 (0x00071ca0)
[2019-02-08 14:05:23.062] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get): success
[2019-02-08 14:05:23.062] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), CentralScene Supported Get
[2019-02-08 14:05:23.092] [D] [zway] RECEIVED: ( 01 19 00 04 00 08 11 9F 03 39 00 22 ED BF F9 59 9C 9A F7 B3 D6 DD 6D 53 E0 00 19 )
[2019-02-08 14:05:23.093] [D] [zway] SENT ACK
[2019-02-08 14:05:23.093] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2019-02-08 14:05:23.094] [I] [zway] Node 8:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 5b 02 02 83 1f ]
[2019-02-08 14:05:23.094] [D] [zway] Received reply on job (CentralScene Supported Get)
[2019-02-08 14:05:23.094] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.maxScenes = 2 (0x00000002)
[2019-02-08 14:05:23.094] [E] [zway] Error returned from zdata_set_integer_array(sceneDH, v1SupportedKeyAttributes, count): Bad arguments (-1)
[2019-02-08 14:05:23.094] [D] [zway] SETDATA devices.8.instances.0.commandClasses.91.data.slowRefreshSupport = True
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10 = Empty
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.status = Empty
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.duration = Empty
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.moreStatusUpdates = Empty
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.lastEvent = Empty
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.status = 1 (0x00000001)
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.duration = 0 (0x00000000)
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.moreStatusUpdates = True
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.lastEvent = 466083 (0x00071ca3)
[2019-02-08 14:05:23.095] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.lastSession = 10 (0x0000000a)
[2019-02-08 14:05:23.095] [I] [zway] Using security scheme S2 Authenticated
[2019-02-08 14:05:23.095] [I] [zway] Adding job: CentralScene Configuration Set
[2019-02-08 14:05:23.096] [I] [zway] Adding job: Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set
[2019-02-08 14:05:23.113] [D] [zway] SENDING (cb 0x77): ( 01 1A 00 13 08 13 9F 03 93 00 B8 5A 7F 5C 23 F3 A6 25 E0 3F 62 55 04 31 3F 25 77 C0 )
[2019-02-08 14:05:23.113] [D] [zway] Secure payload: ( 6C 01 8A 03 5B 04 80 )
[2019-02-08 14:05:23.116] [D] [zway] RECEIVED ACK
[2019-02-08 14:05:23.120] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2019-02-08 14:05:23.120] [D] [zway] SENT ACK
[2019-02-08 14:05:23.120] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Response received - transfered to encapsulated jobs
[2019-02-08 14:05:23.120] [D] [zway] Delivered to Z-Wave stack
[2019-02-08 14:05:23.146] [D] [zway] RECEIVED: ( 01 18 00 13 77 00 00 02 00 E0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 60 )
[2019-02-08 14:05:23.146] [D] [zway] SENT ACK
[2019-02-08 14:05:23.147] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Callback received - transfered to encapsulated jobs
[2019-02-08 14:05:23.147] [I] [zway] Job 0x13 (CentralScene Configuration Set): Delivered
[2019-02-08 14:05:23.147] [D] [zway] SendData Response with callback 0x77 received: received by recipient
[2019-02-08 14:05:23.147] [D] [zway] Job 0x13 (CentralScene Configuration Set): success
[2019-02-08 14:05:23.147] [I] [zway] Waiting for job reply: CentralScene Configuration Set
[2019-02-08 14:05:23.147] [I] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): Delivered
[2019-02-08 14:05:23.147] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2019-02-08 14:05:23.147] [D] [zway] SETDATA devices.8.data.lastSend = 466088 (0x00071ca8)
[2019-02-08 14:05:23.147] [D] [zway] Job 0x13 (Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set): success
[2019-02-08 14:05:23.148] [I] [zway] Removing job: Security S2 Encapsulation (S2 Authenticated), CentralScene Configuration Set
[2019-02-08 14:05:23.176] [D] [zway] RECEIVED: ( 01 19 00 04 00 08 11 9F 03 3A 00 D1 25 FF 11 22 4F 36 A1 E7 19 91 99 AB E0 00 00 )
[2019-02-08 14:05:23.176] [D] [zway] SENT ACK
[2019-02-08 14:05:23.177] [D] [zway] SETDATA devices.8.data.lastReceived = 0 (0x00000000)
[2019-02-08 14:05:23.178] [I] [zway] Node 8:0 CC SecurityS2: passing S2 Authenticated decrypted packet to application level: [ 6c 02 0a 00 00 ]
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.status = 0 (0x00000000)
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.duration = 0 (0x00000000)
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.moreStatusUpdates = False
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10.lastEvent = 466091 (0x00071cab)
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.instances.0.commandClasses.108.data.10 = Empty
[2019-02-08 14:05:23.178] [W] [zway] Node 8:0 CC Supervision: Setter was not accepted by the recepient: CentralScene Configuration Set
[2019-02-08 14:05:23.178] [D] [zway] Delaying request job (CentralScene Configuration Set) by 0 seconds
[2019-02-08 14:05:23.178] [D] [zway] SETDATA devices.8.data.lastSendInternal = **********
[2019-02-08 14:05:25.151] [D] [zway] Job 0x3b: deleted from queue
[2019-02-08 14:05:25.293] [W] [zway] Reply not received before timeout for job (CentralScene Configuration Set)
