Do not see the firmware upgrade to 5.36
nkraus
Post by nkraus »
I have two Raspberry Pi, one with a razberry and one with UZB. I could update the UZB to firmware 5.36, but with my razberry it does not show me the firmware. I am on 5.27. I am sure, that I have seen the update a few weeks ago, but now it only says that I do have the latest firmware.
I also have the problem that I have integrated a samsung smartthings and it can not finish the interview (security is not working). I absolutely know that it worked before. I tried software 2.3.8 and 3 Beta, but no way to solve this two problems. I already wrote the support, but absolutely no feedback since weeks.
Norbert
Re: Do not see the firmware upgrade to 5.36
Hello!
5.36 on RaZberry was disabled due to a potential problem with blue boards. If you have a blue one, you will not be able to upgrade ;( this is due to a production issue. We are working on a solution.
As for missing interview, logs are needed
nkraus
Post by nkraus »
Thanks for the information. I do have a green razberry board. I will wait for a solution.
What is your current version?
nkraus
Post by nkraus »
My actual version is 05.27
Please insert token "all". If you have a green board, you can do it. With blue do not!
nkraus
Post by nkraus »
Thank you - it worked.
Norbert
Helleman
Post by Helleman »
I have the version 5.04, but it says ”Your stick uses the latest firmware”.
I tried writing “all” in the “insert your token” square, but nothing happens at all.
What do I have to do?
I am doing this so that I can update to the most recent z-wave, I currently run 2.3.8.
Better to first upgrade
Helleman
Post by Helleman »
Ah, ok, I’ll try that, thanks.
Thought it needed to be the other way around.
