How to remove a zombie device?
Posted: 03 Mar 2019 18:06
by software-guy
Hello everyone.
I have just started playing with my Razberry and one single NeoCoolcam door sensor, and the following happened.
1. I have installed the Razberry and Z-Way on my existing Pi 3B+, paired the sensor, worked great!
2. My Pi experienced a hardware problem, so I have mounted the Razberry on another Pi (3A+), reset the sensor and installed everything again.
3. Before even pairing the sensor, a device (#2) was present. I can't remember the name of it.
4. After successfully pairing, I now have a device #3 which works fine but the device #2 is still present. All I can do with it is rename it.
In the expert UI, the first tab ("Interview") displays a red 0% for device #2, whereas device #3 show a green 100%.
Can someone tell me how to get rid of this device #2?
Thanks in advance for your help!
Re: How to remove a zombie device?
Posted: 04 Mar 2019 22:34
Go in Network Control and use remove failed. You might need to check connectivity to this device first in Status tab
