Z-way device description
AlesKO
Post by AlesKO » 18 Mar 2019 13:27
You can add new device to Z-Way using 'Z-Way Smart Home' or 'Expert UI'.
Only recently I discovered that Z-Way Smart Home UI has different (much better) device descriptions.
In past I added all devices from Expert UI without selecting proper (unexisted) device descriptions. Now I would like to change device descriptions from Z-Way Smart Home UI. But I can not figure out how? Is it really possible only when adding new devices? There is no option in Manage > Configuration menu.
Please help me.
Alex
Re: Z-way device description
Post by PoltoS » 07 Apr 2019 20:44
Go in Devices->Z-Wave->Manage
AlesKO
Post by AlesKO » 09 Apr 2019 10:17
OK, but there is no option to select / change device model. :shock:
enbemokel
Post by enbemokel » 09 Apr 2019 11:10
I assume that Polto think about the button "Select Device Description"
AlesKO
Post by AlesKO » 11 Apr 2019 00:03
'Select device description' exists in ExpertUI only :-)
And there is differnet (older) list of Fibaro devices.
I like the way it is implemented in normal UI, but there is no way to change device (to correct/newer model)
