Voltage Meter
cmpts_cmp
Voltage Meter
Post by cmpts_cmp »
Hi
Looking at using a ZUno as I use zwave for home automation.
Are there any circuit layouts and code already out there to read the voltage using a zuno?
I'd like to monitor a 12v caravan/trailer battery
Cheers
Re: Voltage Meter
You can use the Z-Uno shield with jampers set to 0-12 V on ADC pins.
Or Z-Uno with a voltage divider (to resistors) to adopt 0-12 to 0-3. In fact better 0-15 to 0-3 as the battery can give more than 12 V.
cmpts_cmp
Re: Voltage Meter
Post by cmpts_cmp »
I think the z-uno voltage divider option is a good solution.
Are there any code examples out there? I did try this one but the library is different / not compatible so errors.
https://www.electroschematics.com/9351/ ... voltmeter/
Re: Voltage Meter
I would suggest you to have a look on our LCD libraries that are in the package with Z-Uno
