I had to reinstall Raspbian. I want to restore my backup file (ZAB). Before I've done it in UI expert there was my devices (without names and details but there was 20 devices). I didn't restore Z-Wave network -> there was no devices. Reboot didn't help. So I try with Z-Wave network -> even worst. Can I do something with it or not?
Thanks PoltoS, I figured it out on my own yesterday and here is a more a more detailed description:
As so often it is trivial. The problem is the UI port of the controller. The serial port of the controller has to be adjusted under Applications/Active Apps. For the GPIO Z-Wave controller it is /dev/ttyAMA0. For the USB stick /dev//dev/ttyACM0
Dear friends of zwave.me: you should urgently work on the documentation and the support, so that Z-Wave finally gets out of the handicraft corner. I assume that the majority of users have already invested a lot of money in this solution and can therefore expect more professionalism.
Please provide logs. Are you sure BT was disabled by the install script. If it is a Pi4, the script might not be correct for some models. What is your Pi?
