Controlling multiple Z-Wave RGBW Bulbs
donaluis
Post by donaluis »
I've got two of the Aeotec ZWA002 LED Bulb 6. Using an Aeotec Z-Stick and Home Assistant/OpenZWave.
Whenever I issue a command to change both bulbs to a new color, one starts to change noticeably before the other. Sometimes 3-8 seconds before. They both get to the new color but looks visually odd when changing out of sync. new projects in kanjurmarg
Is this a limitation to the design of Z-Wave? Could it be something up with my Z-Wave network? Both bulbs are very close to the controller and I've healed multiple times. It's just annoying that they don't change colors at the same time. 1 bhk in vikhroli
Is anyone able to change two Z-Wave bulbs at the same time and have them actually update at relatively the same time?
michap
Re: Controlling multiple Z-Wave RGBW Bulbs
Post by michap »
donaluis wrote: ↑
11 Oct 2019 09:29
I think it is not the right forum for your question ;)
Generally, every Z-Wave device have a unique ID and each node is controlled individually, so that there can be no influence within the network.
I'm not sure, but I think HomeAssistant have integrated the OpenZwave Control Panel - so that you can check it here or in HAssistant logs.
Michael
