UZB upgrade issues
Posted: 19 Oct 2019 19:14
by ValiE
Hi guys,
I'm facing some problems when I want to figure it out what step should I make to upgrade my stick.
root@raspberrypi:~/ZMESerialUpdater/arm# ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyACM0 | grep -E "(FREQ|VERSION)"
                 [b]VERSION:  05 19  VENDOR:  01 15
                    FREQ:  EU[/b]
In that graphical view of update steps i'm clicking on the grey bubble for UZB/5.19/29304 I get an json file that contains:
"fileURL": "UPD_FIRMWARE_UZB500_from__05_13__to__05_17.bin",
      "released": "2017-05-19",
      "comment": "Update from 5.19 to 5.23",
Using wget and update command I'm able to successfully upgrade the stick using "UPD_FIRMWARE_UZB500_from__05_13__to__05_17.bin" firmware
The problem is that after updating the firmware i get the same output:
FREQ: EU
What i'm doing wrong or i'm missing?
Re: UZB upgrade issues
Posted: 20 Oct 2019 11:30
Make sure the bootloader CRC is 29304 (dec).
Posted: 20 Oct 2019 11:40
Better use Z-Way to do the upgrade
Posted: 22 Oct 2019 18:18
by ValiE
20 Oct 2019 11:40
I thought I need a license for installing Z-way. It is possible to use it in trial mode? I don't plan to use this software other then what you said - my plan was to use the stick attached to a Raspberry PI running Home Assistant
Posted: 22 Oct 2019 22:37
Upgrade is possible without a license. And in the new v3.0.0 there is a Demo button - you can test Z-Way before buying it.
Posted: 23 Oct 2019 10:09
by ValiE
22 Oct 2019 22:37
Thanks @PoltoS i'll give it a try, thanks a lot for your time
Posted: 24 Oct 2019 01:04
by ValiE
@PoltoS I've followed your indication about upgrading UZB from Z-way without success: I was only able to install Z-way v2.3.8 (upgrading to newer 3.0 ends up without being able to logon on web page) and I cannot see any new firmware for the stick: "Your stick uses the latest firmware".
You said I need to make sure it has the bootloader CRC at 29304 but mine doesn't look nothing near that:
SERIAL INFO
          ZME_CAPABILITIES
                     UID:  BA 0C 30 4D BB CE DE 41 93 A1 9D 6E 9B 02 85 2F
                  VENDOR:  00 00   NODES: FF
                   FLAGS:  05 00 00 00 00 00 00 00 00 00 00 00 00
          [b]FIRMWARE CRC
                    BOOT:  BB BB[/b]      FW:  42 71
          MISC
                    FREQ:  EU
                                         NVR Content
          Prog/erase lock :  FF FF FF FF FF FF FF FF, Read back lock: FF
          Rev 01, Cal 03, TXCal  16 12, SAW  FF FF FF FF, Pin FF, CRC  EE F5
          NMV: CS 15, TYPE 02, SIZE  01 00, PSIZE  01 00 (EEPROM M25PE20)
          USB: VID  FF FF, PID  FF FF, UUID  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          FACTORY ID: WEEK 255, YEAR 255, CHIP  FF FF, SER  FF FF, WS 255, HWREV: FF FF, CRC8 FF
