Problems to bind sensors
dg3feh
Post by dg3feh »
Hello! I run an UZB Stick on a RaspPi 2 Model B with Raspian and z-way server 3.0. f I initiate a sensor reset, the UZB starts flashing in blue, and the reset procedure works. If try to add a sensor with the Start command, the UZB does not flash and the adding does not work. Is that a bug with in the software?
BR Holger
Re: Problems to bind sensors
I believe you don't have a license in your UZB. Please go to Expert UI, Network, Controller Info, License, Demo to get a demo license
