Unexpected behavior with “heating control” schedule
markchang
Post by markchang »
I’be setted up my secure 321 and secure boiler control, and I’m testing the heating control.
I have an abnormal behavior, at a precise hour the temperature changes from 18 (e save) to 20 (comfort) and I have not this change in my settings.
I have tested these configurations in the schedule:
From 23:00 to 13:00 18deg and from 12:00 to 23:00 20deg, and now, only 20deg from 13:00 to 23:00.
At 11:29 the temperature has changed from 18 to 20
Previously I have tested some other configurations, but I’ve deleted them.
I see something strange too. I’ve created two schedules in the web browser from my iPhone, the one for 18deg and the one for the 20deg, but after save it, if I see the heating control in the computer, via web, I see only the 20 deg zone in blue.
I
Think it exist a doble configuration or something similar, can you help me to fix this behavior problem?
J
michap
Contact:
Re: Unexpected behavior with “heating control” schedule
Post by michap »
Have you tried to restart Z-Way?
I had a similar problem with another module, after restarting Z-Way everything was ok.
(its not a "solution" but could help to understand the problem)
Michael
markchang
Post by markchang »
I have deleted all the configurations of heating control, I’ve restarted, created one schedule, and at this moment, it changes ok.
I will give feedback, but is strange
piet66
Post by piet66 »
Automation/schedule doesn't work properly. It happens, that old cron tasks are not deleted and remain active.
I think it's the same issue as https://github.com/Z-Wave-Me/home-automation/issues/497
Only possibility to repair this is to restart z-way-server service.
RaZberry by Z-Wave.Me ZW0500 6.82.01 05.39/35498 1024/2
Z-Way version v3.1.2 from 2020-12-31
markchang
Post by markchang »
Hello Again.
At this moment, seems to be ok after schedule deletion and raspberry restart
Thanks for the answers
J
piet66 wrote:
03 Nov 2019 18:10
Fixed it for v3.0.2 (soon)
markchang
Post by markchang »
I hope 3.0.2 doesn’t crash all the system as 2.3.8 to 3 update 😞
J
We hope it too. Transition from a tgz to deb was not that smooth for some users as we expected
