Heating control nor climate control app are working
Re: Heating control nor climate control app are working
We plan to make a new release this week. It will address many fixes in the Heating app. Hope we not to let you freeze
You can even test it z-way-3.1.1-58-gf60d75f_armhf.deb
Thanks for the update.
Time driven functionality is still under test, but for now it looks good. The new features are also welcome.
One improvement point would be still nice to get, in the room view:
- deleted rooms should not be displayed
- room without thermostat should also (optionally?) not be displayed
See the attached image for details.
- RoomView.PNG (126.15 KiB) Viewed 112 times
Update:
On time driven (scheduled) mode there some issues I see:
- when time driven mode is activated (changed from another mode) the comfort temperature is set, not the one which should be set according to the schedule (this is recovered at some point when the schedule requires a change of the settings)
- rooms without a schedule are being set (and reset) to the comfort temperature.
IMHO, in such a case there should be no scheduled changing of the values, except the very 1st activation and that one to the saving temperature.
... there is an easy workaround for this, by setting up a schedule, however, some improvement would be nice here.
