Adding multiple elements - include process hanging
MUDO
Post by MUDO »
Hi guys. Im new here. I want to add more elements with one Zuno. I used example code "Multilevel Sensor" (https://z-uno.z-wave.me/examples/MultilevelSensor/). It works great.
Then I added new element with own channel. This code is supposed to work even new element is just a "copy" of behaviour of the first element. I cant finish include process. It hangs on 95%. I added new element, channel and getter. Editied code is below and all changes are highlighted in bold. Sorry for not putting it as a code style, wanted to use bold and it is not possible there.
Not ecven luck with this channels setup:
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getter),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getter2)
HW:
- Raspberry Pi 3+
- RaZberry
- Arduino IDE v1.8.10
Any help please? Im pretty sure, Im missing some detail here and Im too blind to spot it.
// LED pin number
// 13 pin - user LED of Z-Uno board
#define LED_PIN 13
// button pin number
// 18 pin - button(BTN) of Z-Uno board
#define BTN_PIN 18
// channel number
#define ZUNO_CHANNEL_NUMBER_ONE 1
#define ZUNO_CHANNEL_NUMBER_TWO 2
// variable to store current button state
byte lastButtonState;
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL_GENERAL_PURPOSE(getter),
ZUNO_SENSOR_MULTILEVEL_GENERAL_PURPOSE(getter2)
// the setup routine runs once when you press reset:
void setup() {
pinMode(LED_PIN, OUTPUT); // set LED pin as output
pinMode(BTN_PIN, INPUT_PULLUP); // set button pin as input
// the loop routine runs over and over again forever:
void loop() {
// sample current button state
byte currenButtonState = digitalRead(BTN_PIN);
if (currenButtonState != lastButtonState) { // if state changes
lastButtonState = currenButtonState; // save new state
zunoSendReport(ZUNO_CHANNEL_NUMBER_ONE); // send report over the Z-Wave to the controller
zunoSendReport(ZUNO_CHANNEL_NUMBER_TWO); // send report over the Z-Wave to the controller
if (currenButtonState == LOW) { // if button is pressed
digitalWrite(LED_PIN, HIGH); // turn the LED on
} else { // if button is released
digitalWrite(LED_PIN, LOW); // turn the LED off
byte getter() {
if (lastButtonState == 0) { // if button is pressed
return 0xff; // return "Triggered" state to the controller
return 0; // return "Idle" state to the controller
byte getter2() {
Re: Adding multiple elements - include process hanging
Make sure to re-unclude your device afte changing the channel type. This is a MUST in Z-Wave.
Check the second [!] notice on https://z-uno.z-wave.me/Reference/ZUNO_SETUP_CHANNELS/
If this is not your case, please let us know what is missing in the interview
MUDO
Post by MUDO »
Thx for reply. I will check (cant now). I excluded ZUNO before including for sure. Any way how to find out "please let us know what is missing in the interview". Do you mean logs? Thx.
Logs or Interview Results page
