Z-Way server does not report same value multiple times
Posted: 06 Jan 2020 13:30
by vinisz
Hi All,
For logging purposes (InfluxDB/Grafana) , I want my fibaro FGMS-001 multisensor to report the temperature every 15 minutes, no matter if the temperature has changed or not.
I can do this by configuring parameter 64 to 900, which seem to wotk out fine.
however, when there is no change in temperature, I do see the device report it's value in the sniffer, but the Z-way gui events screen is not displaying this same value again, 15 minutes later.
It seems that z-way events screen is only displaying changes and is ignoring the same value reported again if it is unchanged.
As a result, I'm also not getting that value into node-red every 15 minutes when there is no change.
Expected behavior: Also display the event, even when there is no change.
I've attached two screenshots in which you can see that the same value is reported at 10:48 in the Zniffer, but there is no value vissible in the event monitor at 10:48 (because no change)
Re: Z-Way server does not report same value multiple times
Posted: 06 Jan 2020 23:03
If think it is somewhere here:
https://github.com/Z-Wave-Me/home-autom ... ce.js#L235
You can remove this check and get every value change.
Posted: 07 Jan 2020 13:22
by vinisz
OK, I'm not a developper but can you make this an option in next version or something ? I really do not like to change code which might be overwritten in new versions.
Posted: 08 Jan 2020 05:12
Well, this will produce quite a lot of useless traffic, i/o, events and might affect many aspects, so this is not something we can do for all users. I understand your frustration, but we need to think carefully and test before changing this.
Posted: 09 Jan 2020 00:23
by platypus
For data logging I use the app „sensor values logging“. It executes HTTP requests or saves to a JSON file every time a sensor updates, no matter if the actual value has changed. Maybe this could be an option for you?
Posted: 10 Jan 2020 14:26
by vinisz
platypus wrote: ↑
09 Jan 2020 00:23
Thanks ! let me look into that...
Posted: 06 Jul 2020 10:36
by AlesKO
Can someone explain how to use Sensors Value Logging App.
Simple recording service recommendation?
