what can be the best way to define a rule execute at defined time only?
As simple sample I want to switch off a light at 8:00.
In "rules" I can set only if "time >= 08:00" - but this means that I never can switch the light on later, it will be switched off by rule then again.
Why there is no option if "time = 08:00" ?
(yes... I coud add "and if time <= 08:02" as sample....)
Or If I want to switch off the light at 8:00 or if the luminiscence >150lx.
After switching on the light manual again - it will be switched off.
Would be nice to have an option "execute only once per day" .
Of course there is a workaround using a virtual device and save the state of rule and include this into the rule, but it is not the easy way
I have tried the option "Check the rule for every change of state of a device listed under Conditions" - but it cannot be used for this case.
Any idea, how to make it easy for users?
Thanks!
Michael
