Z-Way: Rule execute once only
Posted: 15 Jan 2020 12:03
by michap
what can be the best way to define a rule execute at defined time only?
As simple sample I want to switch off a light at 8:00.
In "rules" I can set only if "time >= 08:00" - but this means that I never can switch the light on later, it will be switched off by rule then again.
Why there is no option if "time = 08:00" ?
(yes... I coud add "and if time <= 08:02" as sample....)
Or If I want to switch off the light at 8:00 or if the luminiscence >150lx.
After switching on the light manual again - it will be switched off.
Would be nice to have an option "execute only once per day" .
Of course there is a workaround using a virtual device and save the state of rule and include this into the rule, but it is not the easy way ;)
I have tried the option "Check the rule for every change of state of a device listed under Conditions" - but it cannot be used for this case.
Any idea, how to make it easy for users?
Thanks!
Michael
Re: Z-Way: Rule execute once only
Posted: 15 Jan 2020 16:00
by enbemokel
for a simple sample, it would be possible to use the "Schedule" app?!
But if it should be more powerful you might have to use different scenes....didn“t test it, no need so far ;-)
Posted: 15 Jan 2020 19:02
by michap
Schedule App does not have the rule features ;)
Additional - for users we have now the 6 "Automation" buttons, so it would be great to integrate it here in rules.
I think it is a standard rule set what I described, nothing special.
I personal have some more complicated rules, most of them have fixed time (or sunset/sunrise with delay) or a sensor value condition - and the option to modify afterwards by hand the target device (as sample roller shutter, light etc.). For sunset/sunrise only it is not a problem...
This is why the "automatic correction" of the rule afterwards interferes ;)
With "execute once only per day" it could be solved and would be easy to understand.
And the "time = xx:yy" option as trigger of course, what could me more interresting.
Michael
(edited at 17:56)
