Z way server libraries present, but fails to start
Posted: 24 Jan 2020 22:36
I am trying to set up my razberry stick with z-way-server. The server failed to start from the service, so I tried to run it from the command line. Via the command line the libraries are not found, even though the libraries are present. See the output below.
I tried to run the install script anew, but now the service is not available anymore.
Can someone help? Service was available before the reinstall.
root@loihi:/opt/z-way-server# ldd z-way-server
linux-vdso.so.1 (0x7e9de000)
/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so => /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so (0x76ec1000)
libzcommons.so => libs/libzcommons.so (0x76eae000)
libzwayjs.so => not found
libv8.so => libs/libv8.so (0x7690e000)
libxml2.so.2 => not found
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x768fb000)
libcrypto.so.1.1 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1 (0x766ea000)
libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x766c0000)
libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76579000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x764f7000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x764ca000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x7637c000)
librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76365000)
/lib/ld-linux-armhf.so.3 (0x76ed6000)
root@loihi:/opt/z-way-server# echo $LD_LIBRARY_PATH
/opt/z-way-server/libs
root@loihi:/opt/z-way-server# ls /opt/z-way-server/libs -lah
total 11M
drwxrwxr-x 2 root root 4.0K Jan 23 19:28 .
drwxrwxr-x 12 root root 4.0K Jan 23 21:52 ..
-rwxrwxr-x 1 root root 467K Jan 21 16:40 libcurl.so
-rwxrwxr-x 1 root root 467K Jan 21 16:40 libcurl.so.4
-rwxrwxr-x 1 root root 467K Jan 21 16:40 libcurl.so.4.6.0
-rwxrwxr-x 1 root root 7.4M Jan 21 16:40 libv8.so
-rwxrwxr-x 1 root root 45K Jan 21 16:40 libzcommons.so
-rwxrwxr-x 1 root root 80K Jan 21 16:40 libzenocean.so
-rwxrwxr-x 1 root root 55K Jan 21 16:40 libzs2.so
-rwxrwxr-x 1 root root 543K Jan 21 16:40 libzwayjs.so
-rwxrwxr-x 1 root root 962K Jan 21 16:40 libzway.so
root@loihi:/opt/z-way-server# ls /usr/lib/arm-linux-gnueabihf/libxml2.so.2* -lah
lrwxrwxrwx 1 root root 16 May 26 2018 /usr/lib/arm-linux-gnueabihf/libxml2.so.2 -> libxml2.so.2.9.4
-rw-r--r-- 1 root root 1.5M May 26 2018 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.9.4
root@loihi:/opt/z-way-server# service z-way-server status
● z-way-server.service
Loaded: not-found (Reason: Unit z-way-server.service not found.)
Active: failed (Result: exit-code) since Thu 2020-01-23 21:58:12 CET; 22h ago
Jan 23 21:58:12 loihi systemd[1]: Starting LSB: RaZberry Z-Wave service...
Jan 23 21:58:12 loihi systemd[11400]: z-way-server.service: Failed to execute command: No such file or directory
Jan 23 21:58:12 loihi systemd[11400]: z-way-server.service: Failed at step EXEC spawning /etc/init.d/z-way-server: No such file or directory
Jan 23 21:58:12 loihi systemd[1]: z-way-server.service: Control process exited, code=exited, status=203/EXEC
Jan 23 21:58:12 loihi systemd[1]: z-way-server.service: Failed with result 'exit-code'.
Jan 23 21:58:12 loihi systemd[1]: Failed to start LSB: RaZberry Z-Wave service.
