manual routing
Posted: 17 Apr 2020 22:20
I am trying to learn how to do manual routing. I have a Smartthings hub as the primary controller and the Razberry2 as secondary. I am trying to force a Schlage lock to link to the Smartthings hub via a Jasco light switch.
Using Z-wave Expert UI, I used the "manual routing" button to route a path from the ST hub to the switch and from the switch to the lock. This route shows up under the Network - Route Map - Manual routes. It shows the ST Hub as the " source", the switch as "route between source and destination" and the lock as "destination".
When I hover over the lock in the routing map, it just shows the lock routing straight to the Razberry. Note - the lock was added to the ST hub prior to adding the Razberry to the network.
Am I doing something wrong? how do i get the route map to show the manual routes (I do have "manual routes" checked in the "route map settings").
Thanks,
Lee
Thanks,
Lee
