Extract z-way network security key?
MrRusch
Post by MrRusch »
I have included a secondary controller (Z-stick) in my network, but it is not able to communicate with those devices that have been securely included via the RaZberry. I'm assuming I need to set the Z-way-server's network security key in the secondary controller - but how do I extract it from Z-way-server?
MrRusch
Re: Extract z-way network security key?
Post by MrRusch »
Perfect! Thanks rafale.
Can't believe this is not in the manual or in this forum somewhere.
For completeness - the file is located here:
/opt/z-way-server/config/zddx/homeId-DeviceData.xml
..and the entry here is called "networkKey".
rafale77
Post by rafale77 »
The /opt depends on what OS you have it installed on... On windows for example, it won't be in OPT. Many have it in /ETC on raspbian I believe.
