How to use EasyScripting?
Posted: 11 May 2020 12:47
by shaldi
Hi
I'm quite new to the Z-Way stuff. I saw the announcement of the EasyScripting App that I'm very interested in to bind two systems.
So I would like to use the EasyScripting Module to call a web hook of another system via HTTP POST request. The Javascript code to call the request I got from the example documentation of the App.
But how can I integrate the Script within a (automation) rule? I would like to trigger the script only if a sensor value has reached a specific threshold.
Can I use the EasyScript for automation (rules) or do the scripts has to be "selfcontained" including trigger, conditions and actions (if-then-else)?
Thanks!
Re: How to use EasyScripting?
Posted: 14 May 2020 21:08
Please have a look on the Easy Scripting app - in Chrome it should help you to write the code with a helper.
Posted: 15 May 2020 14:51
by shaldi
Thanks for your reply!
What I don't understand is WHEN the Script is being triggered/called?
How can I add a Trigger Condition (e.g. Pseudo Code: If (rainSensor.value() > 0))?
Posted: 19 May 2020 10:42
by ridewithstyle
it is explained in the the app documentation, the script gets triggered on a value update you can specify (even multiple triggers). In you case, it is rainSensor's value. Find the ID of the sensor reading by browsing to in in ZWay and in the browser link you see something like 192.168.0.255:8083/smarthome/#/element/ZWayVDev_zway_50-0-49-1. Take the Device Identifier into your easy scripting app
### ZWayVDev_zway_50-0-49-1
and everytime the value gets updated by ZWay, your script gets called.
Posted: 23 May 2020 16:22
by shaldi
Thanks for your hints!
Currently my script looks like this:
var req = {method: "POST", async: true}
if (vdev("ZWayVDev_zway_2-0-49-12").value() > 0) {
req.url = "http://<hostname>:<port>/api/webhook/rain"
else {
req.url = "http://<hostname>:<port>/api/webhook/norain"
http.request(req)
The rain rate value has multiple times be over 0.
But the web hooks are not called
Am I missing something? How can I debug this? Is there a log file or something?
Posted: 23 May 2020 16:34
by ridewithstyle
Because you are missing the event trigger
//Trigger this script every time that ZWayVDev_zway_2-0-49-12 gets updated
### ZWayVDev_zway_2-0-49-12
else {
http.request(req)
at the beginning of your script. If your script has multiple values it shall react to you can add additional trigger lines starting with ###.
To simply select those trigger events from all those available on your system, call the easy app code editor from a chrome browser and you see extended support
Posted: 20 Jun 2020 12:09
by shaldi
That did the trick! Thanks a lot
