Controller backup doesn't work - Windows OS
Ricard1
Post by Ricard1 »
Installed 3.0.6 on Win10 OS.
Anyone got Controller Backup and Restore working?
I will not use a Z-Wave Controller in my system as long it does not support Backup function... I have UZB Stick but never got Backup working :(
So, meanwhile that might be fixed I use Aeotech Gen5 Z-Stick (with Domoticz) because Aeotech have at least Backup working for their Z-Stick.
When trying to make a UZB Backup in Expert UI I get this error...
Ricard1
Re: Controller backup doesn't work - Windows OS
Post by Ricard1 »
Hello PoltoS,
Any help/comment on this please?
Thanks in advance!
//Ricard
We will check it. Looks like some Windows specific issue.
Meanwhile you can save config/zddx/* - this is the what you need for restore.
Ricard1
Post by Ricard1 »
Thank you, I think there is a reason to check even z-way system backup/restore under Windows.... :)
The command you mention to backup controller /zddx/* please explain some more how to use it? I tried to insert in the above url in some variants but did not manage, sorry.
I hope built in function may be easy fixed for you as it is a Windows build issue.
Appreciate very much if you can look into this, then I can say bye bye to my Aeotec Z-Stick :)
Cheers!
We will check and fix it for next release.
As for the workaround, you can just copy one file. Go in Z-Way folder, then config/zddx and find the file with your home id. It contains all the data you need for expert UI
Ricard1
Post by Ricard1 »
Hmm... I want to make an backup of the UZB Controller itself, is that data included in the "home ID file"?
Yes, it is
