Weird behavior in a virtual thermostat
dgumenyuk
Post by dgumenyuk »
Dear z-wave enthusiasts,
I had some weird behavior in a virtual thermostat created using an Aeon multisensor 6 and a Linear FZ20 switch.
Sometimes there is no 'switch on/off' command in the log files, however, the temperature starts increasing/decreasing and behaving not as it should. Did you ever observe something similar? As a fix I think to check the temperature trend and resend the command if the trend is not what I expect. Do you think it's a good idea? Do you have any better ideas?
Thanks in advance for your answers!
Re: Weird behavior in a virtual thermostat
Which app do you use. Thermostat Device? Make sure to set reasonable hysteresis
