to overcome the issue ... I 'm trying to get a fresh install going thru ADD ON and get the following log line in red :
[2023-08-29 23:26:49.935] [C] [config] Read/write access to config folder is not granted
It seems zwave.me home assistant add on ...needs access to SD and do not ..anybody encountered this issue and has a possible fix ?
Thanks a bunch
full log below
2023-08-29 23:26:40.387] [core] Starting automation...
[2023-08-29 23:26:40.415] [core] Starting storage...
[2023-08-29 23:26:40.416] [core] ZWay Automation started
[2023-08-29 23:26:40.990] [core] (Mobile App Support) Notification sent
[2023-08-29 23:26:41.011] [core] (Mobile App Support) Notification sent
[2023-08-29 23:26:41.143] [core] (Mobile App Support) Notification sent
[2023-08-29 23:26:41.224] [core] (Mobile App Support) Notification sent
[2023-08-29 23:26:41.245] [core] (Mobile App Support) Notification sent
[2023-08-29 23:26:47.172] [core] --- Starting ZBW Connect Service
[2023-08-29 23:26:47.173] [I] [core] --- Starting ZBW Connect Service
[2023-08-29 23:26:49.935] [I] [core] Restarting Z-Wave binding (zway)
[2023-08-29 23:26:49.936] [I] [core] Error: Invalid config
[2023-08-29 23:26:49.936] [I] [core] Trying to restart Z-Wave binding (zway) in 10 seconds
Integration with Home Assistant
Re: Integration with Home Assistant
I installed docker and then the zwave2mqtt container - i saw that z-way and zwave2mqtt don't like sharing the serial port (no real surprise).
waplus.win
projectfreetv.onl
waplus.win
projectfreetv.onl
I have HA perform a full backup everyday and just restored the backup and the sensor data is back. krnl download
hdstreamz.uno
hdstreamz.uno
