How does Z-Way handle failed commands?
sofakng
Post by sofakng »
For example, if I tell Z-Way to turn on a switch, does Z-Way assume the command was sent AND received successful?
Also, does Z-Way poll the device after a command was sent to see if the action was successful? (i.e. check if device is turned on if an on command is sent)
Re: How does Z-Way handle failed commands?
Z-Way will do several tries to deliver the command. If it finally fails, it will report it to the caller (if callback is set)
It will also ask a Get() to check the new state of the device.
