Set parameters for Qubino mini dimmer
Posted: 25 Jun 2020 21:24
by Helleman
I have installed a Qubino mini dimmer in my system. How do I configure the different parameters in the Qubino mini dimmer?
According to the manual there are several different parameters to set in the dimmer, but I cannot find them in z-wave.me.
Also, I cannot seem to get the mini dimmer to work with the push function to the led driver. The spotlights are impossible to turn off...
Re: Set parameters for Qubino mini dimmer
Posted: 26 Jun 2020 00:30
Please go in Expert UI -> Configuration -> Select your device -> Configuration tab
Posted: 04 Jul 2020 00:54
by Helleman
26 Jun 2020 00:30
Thanks! I found it.
Also, I solved the problem I had controling the Dimmable leds using the Qubino mini dimmer. It turned out that my electrician connected it wrong and that I needed a led driver supporting trailing edge. It works great now.
Next time I will be connecting it myself, as I’ve done with my other flush switches... ;)
