Page 2 of 3
Re: BUG : 3.0.6 (Probably others...) Battery marked device dead on restart = NOP packets on each unsolicited report
Posted: 07 Jul 2020 19:47
by rafale77
ok So I have struggled mightily to upgrade firmware on both my razberry and my uzb. After a number of tries with the razberry, I managed to get it in. It kept erring out with this message on a rPi3b+:
Error 1 Unknown exception:Can't write NVM data! at=XXXXX
The location at which it stops seems completely random. So far I have not been able to update the uzb. The furthest i was able to reach was 70%.
Any insight as to why this is happening?
Posted: 08 Jul 2020 01:11
Depending on versions sometime you need to add offset in the NVM. I would suggest to use Z-Way to upgrade the UZB firmware.
Posted: 08 Jul 2020 01:21
by anom3
Hi. Just installed 5.39 on one of my UZBs.
A) So far, no dead devices on restart. Will report if they show up.
B) BUG : This no longer works:
5.06: LED can be turned off:
Change it via IP:8083/JS/Run/zway.NVMExtWriteLongBuffer(0x6510,[XX]), where XX is:
0x00 LED used only for memory test when device powers up. Silent mode.
0x01 LED used during memory test and to indicate inclusion/exclusion mode.
0x03 LED used during memory test, to indicate inclusion/exclusion mode and it blinks when data is sending.
C) Possible BUG : On restart I had the NWI packets again. I am unsure if its just once or if it will keep sending them every 5 minutes like before. As soon as I saw them in zniffer I added the following again, and it stopped them:
zway.AddNodeToNetwork(1);
setTimeout(function(){
zway.AddNodeToNetwork(0);
},1000);
Previously I had just this, but this is no longer enough:
Maybe its normal to send the NWI explorer packets once on restart? Like I said, I saw it once and added the above code right away so not sure if its doing the 5 minute cycle like previously.
Will post if anything else comes up.
Posted: 08 Jul 2020 18:44
by rafale77
After a lot of pain, I finally was able to upgrade the uzb with the ZME tool and booted the z-way-server. So far no false IsFailed report.
Posted: 02 Sep 2020 20:12
by rafale77
Seems to be some translation problem with the previous post but... I tend to agree. Upon reboot of the server (not of the zwave chip which has remained on with no reboot for the past 6 months), I can still see randomly devices coming up as "dead". Because the devices changes all the time and they are completely random, I think it is a bug in the z-way-server, tagging devices as dead. It is relatively easy to fix, using the JS API command for battery operated devices and just running a poll on AC powered one but still, it is a bug. I also briefly tested on openzwave and it never does this. So it isn't the zwave chip. It is the z-way-server.
Posted: 10 Sep 2020 00:18
Can you check if is failed field is true or false for such device in EUI? Because in smart home UI there is additional logic on top of EUI
Posted: 11 Sep 2020 20:21
by rafale77
PoltoS wrote: ↑10 Sep 2020 00:18
They show up as isFailed = true and it is actually the command I use through the JS API to make isFailed = false.
I can see from the command queue during the z-way startup that z-way tries to do a check on whether the device is dead. If the dongle does not respond, then it deems the device to be dead. The problem is that upon boot up of the z-way-server the command queue is several hundred commands long and a lot of the commands likely will timeout or run into a collision either through RF or even simply the serial bus. I would suggest not to interrogate the dongle for dead devices upon boot up but to put that functionality elsewhere since the z-way-server seems to have a lot of other things it is trying to do with the dongle when it starts up.
Posted: 12 Sep 2020 02:02
There might be no collision in Serial API. Please show an example of such collision that resulted in isFailed = true.
I believe the chip really believe it is a failed one and answers us that way
Posted: 12 Sep 2020 04:59
by rafale77
I am 100% sure that the chip is not responding that the device is dead. I can plug it into the silabs pc controller and show you that none of the devices ever is tagged as failed. At every single z-way-server start 1 to 3 of my devices show up as failed on z-way and they are never the same one. I can leave it alone and restart z-way and another different set of 1-3 devices will show up as failed. The problem is in the z-way-server process start. I didn't analyze the serial communication, I can only see the command queue and the event where z-way checks if the device is failed and shortly after, it says that it is. It could be worse on a very large network like mine but I think it is due to some communication error between z-way and the dongle or due to some unnecessary check from z-way which is timing out because the zwave dongle is already too busy during the startup.
Posted: 13 Sep 2020 04:13
No need to guess - please check Z-Way log and let's look together in Serial API bytes.
