Schedules - only integer values?
michap
Post by michap »
because of the "unstable" work with Heating Control in this time I have tried to use the "Schedules" for setting the needed values in given time frames.
It is working fine (less comfortable of course, but for easy schedules ok) - the only issue I have found is, that I can set only integer values.
If I set as sample 21.5 degree - will get warning in UI to change it to 21 or 22.
If modify the config.json directly - then it will work as expected.
Maybe it could be done in code that it will work?
Thanks!
Michael
Re: Schedules - only integer values?
Should be fixed in v3.1.2
