Z-Way App for Android
Franz Winchester
Re: Z-Way App for Android
Post by Franz Winchester »
Wanted to try what you proposed, but (click 5 times on OR word between Scan QR) where can I find the "OR" word?
Click on + sign in the list of hubs. If you never get's there, press Cancel button on load.
Franz Winchester
I hit the + and then? No OR
What do you see once you press it? There should be two buttons and OR between
Franz Winchester
I see exactly this screen.
Sorry, in last versions OR was replaced by a dash ;)
Because now more buttons appear here
Franz Winchester
Finally works since v3.1.3 and only one admin. It's ok for me now.
Perfect! Would be glad if you change your review in Google Play ;)
Franz Winchester
Ok, will do.
Jone Warne
Post by Jone Warne »
Franz Winchester wrote:
06 Feb 2021 18:33
I tried again and from this moment on the app does not work any more. Reinstall, update manually to v3.1.2...all a mess.
The app starts, the I scan the QR-code an it starts to connect. After some time it's getting stuck and you can only acceess the "to hub" and try again or access login data, but with no success. I will try to send you a video, but it might be too large, because the process takes several minutes.
Regards
Thomas
Thanks for sharing, it's really helpful.
