Issue removing sensor
Posted: 17 Jan 2021 18:10
by cyb0rg42
I added a First Alert ZCOMBO (CO and Smoke sensor). The interview was not done quite right (Security S2). I want to add the sensor again, but in standard ui the sensor is not visible but in expert ui it is. How can I remove the sensor completely so I can redo the inclusion?
Re: Issue removing sensor
Posted: 18 Jan 2021 02:11
Go to Add and on top press Remove button first.
Posted: 03 May 2021 20:07
by naveen555
Hi
Can you please tell me the steps you used and the setups to have First Alert show up in the z-way devices view? I can't seem to figure it out.
Thanks for your help
Naveen
Posted: 04 May 2021 12:24
by zwaFisher
Search here somewhere. There was a topic describing how to remove dead devices.
Shortly, from an Expert view you need to interview them. It fails. Then you can force removal.
Posted: 15 May 2021 00:50
by JuniEdith
Please help, i am also having the problem of removing the sensor. Let me try to solve the issue with the above recommendations.
