I've purchased and installed the Razberry2. I got it because it supports homekit integration.
I have about 30 z-wave devices in my home, and they are accessible in my Hubitat Elevation hub.
What I would like to be able to do is 'import' all these devices from the hubitat if possible without having to re-discover each of them.
There's an app on the razberry to connect to a hub, but I'm perhaps not using it correctly.
Does anyone here have experience migrating from hubitat?
Also, where can I learn about using the Apple HomePod/Siri to voice control activation on the razberry?
Something like "Hey Siri, turn off the living room fan"
Import devices from hubitat? Integrate homekit?
Re: Import devices from hubitat? Integrate homekit?
Ugh.... no replies, that sucks.
Hi - i too enjoy homekit integration on z-way .
By this time you may have unpair/repair all your devices to z-way
yet if not done and to answer your question :
you should be able to have hubitat accept a secondary controller (in this case z-way)
Once done - put z-way in primary controller mode and hubitat in secondary (ultimatley removing it form the network all together afterwards)
This feature is z-wave DNA yet i do not have hubitat to verify they properly implemented it tghis feature.
Concerning apple siri voice control , it comes naturally enabled since your z-wave device are now part of homekit
hope it helps
hope it helps
