MQTT plugin gets its settings lost on restart
harre
Post by harre »
Not sure where to report issues, I have added some previously on the github repo and haven't gotten any response.
https://github.com/Z-Wave-Me/zwave-smarthome/issues/286
Steps to reproduce:
1. Add MQTT so it shows up at
http://pi:8083/smarthome/#/apps/local
2. Configure app and save.
It shows now on active tab too
3. restart z-way server in terminal
sudo systemctl restart z-way-server.service
The active app is now gone and MQTT reporting have stopped and I need to readd it again
Re: MQTT plugin gets its settings lost on restart
We are making a native MQTT support. Will be ready soon. So may be not worth to bother the author of the old app
harre
Post by harre »
That's great news! Is there any beta version I can try out? :)
There is one, but with JS API only. Very soon (within two weeks) we will have the new easy configurable MQTT app made on top of this JS API.
https://storage.z-wave.me/z-way-server/ ... _armhf.deb
harre
Post by harre »
Thanks for quick response, What can I do with the API and how do I use it?
I'm still quite the noob with js-development, but I have been coding .net for almost 15 years, but this project is so big so it's hard for me to grasp.
Is there any commit for the MQTT-api so I easier trace how to use it?
This is as simple as:
// constructor
var m = new mqtt(server, port);
// handlers
m.onconnect = function() {};
m.onmessage = function(topic, msg) {};
m.onsubscribe = function(topic) {};
m.onclose = function() {};
// methods
m.tlsset(ca_file, ca_path, cert_file, key_file);
m.connect();
m.publish(topic, message);
m.subscribe(topic);
m.unsubscribe(topic);
m.disconnect();
inside handlers (onXXXX use `this` instead of m)
harre
Post by harre »
Thanks for the follow up, but I feel like before I even figure out how to put these pieces together you have already built the working MQTT solution :)
Thanks for the manual link, I'll try to get some time to get antiquated more with the system and try to write my own module
piet66
Post by piet66 »
I like the fact that you now provide a MQTT api.
Unfortunately it comes too late for me. I am almost finished with my own MQTT module. :(
harre
Post by harre »
Share the code and hopefully some parts can be incorporated :)
