Possible to use UZB as Zniffer in Windows?
Posted: 22 Jun 2021 23:46
by sofakng
Is it possible to use the UZB (or RaZberry + USB Serial Adapter) with the Silicon Labs Zniffer?
I'm looking for a simple way to sniff Z-Wave traffic on my Windows PC (without installing a lot of software, etc).
I've tried to use the UZB but the Zniffer doesn't recognize it. (I think it needs special firmware?)
Re: Possible to use UZB as Zniffer in Windows?
Posted: 23 Jun 2021 02:51
No, it is not. The built-in sniffer in the UZB/RaZberry is not a compleate Zniffer like SiLabs. The difference is that it uses another format to report frames, it provides only OWN network packets and only decoded frames. A true Zniffer also shows CRC errors and foreign packets. Beside that there are no real difference.
Posted: 24 Jun 2021 08:10
by lanbrown
sofakng wrote: ↑
22 Jun 2021 23:46
Have you looked at the Z-Wave ToolBox - ZWP-TBX product? Since it has a web based interface, it doesn't matter what device you use to access it since you're using just a browser.
