Even if you set the homekit-skip tag the unwanted device function(s) is still exported to HomeKit and visible in Home app.
Test with a Fibaro Door/Window sensor FGK-101.
Try to get rid of the Tamper switch.
homekit-skip tag does not work in 3.2.0
Re: homekit-skip tag does not work in 3.2.0
Please remove the HomeKit app and set it up again. HomeKit was reworked a lot. You certainly still have the old app code in userModules folder.
Hey PoltoS
The test environment is new, new RPi4B, new installation of Rpi OS, new z-way server 3.2.0 - no old data. New iPhone with different clean iCloud. And only ONE sensor from Fibaro.
I removed the HomeKit App as you suggested.
I removed the Bridge from the iPhone.
Reinstalled the Bridge and the name set in HomeKit App was NOT transfered.
The HomeKit skip tag still does not have any effect !!
Please watch the exclusive video that I post here.
Oh and the setup is a test only - not my day-to-day iPhone
https://www.icloud.com/sharedalbum/#B145fu2MuqXVEW
Good luck
Good luck
