Very slow response after 3.2.0/1
Re: Very slow response after 3.2.0/1
I can only help to find the three appropriate files (using terminal `find` tool) in your node-red and replace with the three files I've changed.
In brief you need to replace those files:
node-red-contrib-zway/lib/zway-socket.js
node-red-contrib-zway/nodes/server.js
node-red-contrib-zway/nodes/server.html
with those downloaded from:
https://raw.githubusercontent.com/bkord ... -socket.js
https://raw.githubusercontent.com/bkord ... /server.js
https://raw.githubusercontent.com/bkord ... erver.html
If you experience issues, let me know and I assist you (write on support@ or in PM)
vinisz
Post by vinisz »
@poltos, was this issue already solved ? I'm not really willing to upgrade again and try things like this and the "hope" I can downgrade again if it does not work.. To me, that sounds like playing trial&error with the customer
Unfortunatelly node-red is not made by us - it is a community work. We have contacted the developper in order to check that my contribution to that integration solved the issue. Hope soon it will be confirmed. We will make a notice about it.
vinisz
Post by vinisz »
Poltos,
I'm testing you Zway node-red adjustment for 3.2.1
https://github.com/bkorda/node-red-contrib-zway/pull/11
I need to know what I shoud enter as "Z-way Authorization token"
If you can respond fast please would be nice, cause now connection is down...
Thank you
Go in Menu -> Settings -> Users -> (select your user - preferably not admin - and grant him access to devices) -> API Token
Note that if you are connected via find.z-wave.me, the token will have the first part before / too, and you can access your Z-Way with this token remotely via find.z-wave.me url.
vinisz
Post by vinisz »
@poltos, we spoke on github already about this... not working, (crashes node-red) , let's wait for a solution... (Or I have to switch to mosquitto...)
