Google Home + Scenes
SirHegel
Post by SirHegel »
Has anyone managed to get scenes working with Google Home? It is quite straightforward to create a Routine in Google Home and activate scenes using "Adjust scenes" action. Google Home lists scenes correcly and let's you check ones you would like to activate. Unfortunately it doesn't quite seem to work. When the routine is activated, Google Home reports it as done with a sound effect, but nothing happens. When tailing z-way server log, you can clearly see that proper api is being called, but perhaps with wrong parameters?
[2021-11-05 00:58:07.112] [I] [core] ---  Scenes_28 performCommand processing: {"0":"off","1":{}}
[2021-11-05 00:58:07.464] [I] [core] ---  Scenes_29 performCommand processing: {"0":"off","1":{}}
Is there something I am missing, or is this a bug in the firmware? I am using v3.2.1.
