Raspberry/Debian Bullseye
Is it save to update to Debian Bullseye?
Re: Raspberry/Debian Bullseye
No. Just tried. It is not supported.
I did the manual update method that is not supported on one of my Raspberry Pi's running Z-Way 3.2.1 and it still runs.
We have a test build that supports both Raspbian bullseye and buster:
It might give you an error due to missing libmosquitto1. If so, just do
Also, note that until the release WebSockets client will also not work. Only a few customers are using it, so I'll not post a recipe here - this will be fixed in a few days once the official release is out.
PKG=z-way-3.2.1-29-g6bdd76fe_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
sudo apt --fix-broken install
Bullseye is now supported. Please follow the standard installation process.
Read more: https://forum.z-wave.me/viewtopic.php?p=91811#p91811
