Error in RaspbianInstall script
Posted: 26 Nov 2021 18:01
When running the installation script on a raspbian buster installation (to manually update to 3.2.1 from 3.0.6):
there is an error because it remarks it is not for my installation, I think the problem is in the version check "-o" instead of "-e" at line 17.
There is also a problem with the script, requiring a version for libmosquitto1 that is not available in the buster distribution, even after update: is there a revised version of the script or a workaroud that can be used for the update?
Thank you.
wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bashThere is also a problem with the script, requiring a version for libmosquitto1 that is not available in the buster distribution, even after update: is there a revised version of the script or a workaroud that can be used for the update?
Thank you.
