What happened with the Route map in v3.2.2?
Going to Expert UI - Analytics - Route map, the Home Screen for Expert UI pops up instead of the Route map.
Route map missing
Re: Route map missing
It works fine for me.
It moved from Network to Analytics.
Try clearing your Browser Cache.
had the same issue, also with the new packets page.
Not sure if a reboot soved this or you have to wait some hours to get data in there.
I assume if you test it now it will work
It works now, without any intervention on my side.
Pure magic.
Pure magic.
