Information Widget is doesn't show up in Apps anymore
Posted: 04 Dec 2021 13:41
by piet66
since recently, the app InfoWidget isn't shown anymore in Active Apps and in Local Apps.
Files still exist in modules folder. Module and Instances are started at boot without any error message in log. The InfoWidget instances are working, all defined virtual devices are existing. In config.json the instances look correct. But the module isn't shown anymore in Local Apps and no instances in Active Apps.
Does anyone have an idea how to get them back ?
Screenshot 2021-12-04 at 11-24-59 Z-Wave Smart Home.png (27.39 KiB) Viewed 7212 times
There are some error messages in console log. No idea if they have anything to do with it:
Layout-Darstellung wurde erzwungen, bevor die Seite vollständig geladen war. Falls Stylesheet noch nicht geladen sind, kann dies zu einem kurzzeitigen Darstellung des Inhalts ohne Formatierung führen. build.js:6:29825
XML-Verarbeitungsfehler: Syntax-Fehler
Adresse: http://192.168.178.22:8083/smarthome/#/apps/instance
Zeile Nr. 1, Spalte 1: smarthome:1:1
Die drawWindow-Methode von CanvasRenderingContext2D ist veraltet. Verwenden Sie stattdessen die Erweiterungs-API tabs.captureTab https://developer.mozilla.org/docs/Mozilla/Add-ons/WebExtensions/API/tabs/captureTab pagedata-script.js:1:12465
Source-Map-Fehler: Error: request failed with status 404
Ressourcen-Adresse: http://192.168.178.22:8083/smarthome/app/js/build.js?rel=v1.13.1
Source-Map-Adresse: angular-websocket.min.js.map
Re: Information Widget is doesn't show up in Apps anymore
Posted: 04 Dec 2021 14:48
by piet66
No sooner do you call for help than the enlightenment comes: I had switched off 'Show System Apps'.
Didn't know that Information Widget belongs to System Apps.
